I/O settings with Pro Tools 11, and Presonus 16.4.2
Hi, I am having a issue getting master fader to work as my playback in pro tools 11. I can use each individual output as a playback, just not master fader. I have tried default settings in pro tools. I also have created custom setting that work the best. I have included pictures of input, output, and mixer settings.
Re: I/O settings with Pro Tools 11, and Presonus 16.4.2
Then on my channel strips I have the output set to MIX OUT L-R and the Master Fader the same. I don't see you assigning the L R to any outputs.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
Can you also post a screenshot of your Setup>IO>Bus tab so we can see the output mappings you have set.
Have you seen this... http://support.presonus.com/entries/...-ProTools-9-10 |
We have just recently made the switch from logic pro X to Pro Tools 12. I've installed Pro Tools 12 now but there is no audio coming through my speakers and the board is not seeing any audio. We are using the "Presonus studiolive 32RML AI" just FYI.
The hardware and playback engine is set to "Presonus Firestudio." All my I/O's are correct. I set my output to "ch. 33-34" (which is set on my core audio and logic) I can get audio playing from Logic and simply from iTunes. But it doesn't seem to be getting any audio from pro tools. Is there a step that I am missing? Help me PLEASE! |
Are you using the Ethernet port? Make sure the Ethernet box is checked under Peripherals in PT as that can uncheck sometimes when deleting Preferences etc.
Have ypu tried launching with the N key held down and when popup window appear choose the Presonus as your playback engine and see if that helps. If it does goto settings and i/o and press default on all tabs even if you done this already just to be 100% certain it is set up straight.
IIRC Pro Tools will only see the first 32 I/O. Try setting your I/O as 1-2.
That is very true and likely the problem. Sent from my iPhone using Tapatalk |
do you mean setting my hardware outs to be 1-2? Ive set my i/o in pro tools as 1-2 and nothing happened already.
The actual IO in pro Tools needs to be within the first 32 outputs. What they are called is irrelevant.
Can you show exactly what you are doing with screenshots of the Setup>IO>Output pages and the track IO selectors. But you need to post images that we can actually read the text on. When you say it does not work what exactly do you mean? search through the IOs until you find something working. Make sure Pro Tools is the only thing trying to access the interface. Sent from my iPhone using Tapatalk |
Pro tools 10 and Presonus 22 vsl | DCGRIFFITH | macOS | 5 | 04-28-2013 04:02 PM |
using presonus studiolive 16.0.2 and pro tools 10 | jrbarraz | macOS | 1 | 08-01-2012 11:06 PM |
Settings on a Presonus Eureka | Mainstream | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-10-2011 08:29 AM |
Settings on Presonus Eureka | Mainstream | Tips & Tricks | 1 | 03-09-2011 11:38 PM |
Pro tools click settings (1/8 notes or 16th note settings )? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2008 09:59 PM |
