Old 02-25-2002, 02:31 PM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
Default Re: Signal path with the PRE I/O - how much in TDM? (Newbie question.)
Are you talking about tracking to disk? Is your concern for monitoring and generating cue mixes? If so, the latency would not be a problem.
Old 02-25-2002, 03:52 PM
Mackenzie Mackenzie is offline
I am, indeed, talking about what the musician hears (say, a vocalist) while tracking. TDM dynamics (good gate / compressor / limiter) + EQ + reverb + chorus doesn't equal unusable latency in a cue mix situation?
I'm asking because a good price/performer with some interesting and substantial convienences might be a:
192 +
8 AD option +
PRE +
PRE +
Waves TDM Gold Bundle (or similar)
...if latency isn't crippling.
Old 02-25-2002, 04:35 PM
ekuehnl's Avatar
ACI/ALP Moderator
That's a pretty standard tracking situation. The latency would not be a problem. BTW, ProTools records pre inserts so you wouldn't be recording any of your plugins. Therefore, you might want to consider saving the EQ and dynamics processing until after tracking. I guess it depends on how you like to do your thing...
Old 02-25-2002, 07:51 PM
MattiMattMatt MattiMattMatt is offline
You could always put the mic through juicy external doo-dads (pre-amp, compressor, etc.) and then go into the Digi Pre at line level.
-MattiMattMatt
Old 02-26-2002, 12:04 AM
Default Signal path with the PRE I/O - how much in TDM? (Newbie question.)
I generally think of, say, a vocal signal path into a DAW including:
- A gate.
- A compressor / limiter.
- Some gentle EQ.
And then on the way out:
- A little reverb.
- A little chorus.
So, using a PRE I/O -> 192 I/O, and without using a compressor, etc. on the direct insert...
Can ProTools TDM handle that kind of a signal chain with reasonable latency?
I'd love to think I can hook a PRE up with a 192 and have everything else be in software/TDM.
(I've been spoiled functionally by the Yamaha 01V with digital dynamics (gate, compressor, limiter) and EQ on every channel, 12 mic pres, 2 stereo effects units, flexible routing, etc, instant recall for everything. Sonically, I think the digital dynamics are EXTREMELY questionable, but the convenience is extraordinary.)
Signal Path (for an 001) Cavet Your Eruptor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-28-2006 12:55 PM
Signal Path bluesna Tips & Tricks 0 01-10-2005 01:02 AM
OT: signal path "bypass" question Dopamine Pro Tools TDM Systems (Mac) 2 08-15-2004 07:46 PM
newbie question: how can i get a recordable SIGNAL! disurbed bassplayer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2003 07:48 AM
Signal Path Question/Master Fader dkrausz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-20-2001 04:57 AM
