Old 10-28-2007, 04:52 PM
mtbass mtbass is offline
Default External firewire hard drive
I recently purchased mbox 2 pro and am currently learning to operate Pro tools. I am using a macbook that has two usb ports and one firewire port which is being used to connect to the mbox interface. I was told that I need to use an external firewire hard drive for recording. My question is...... can I connect the hard drive to the unused firewire port in the back of the interface? .....and if so, what hard drive is compatible with mbox 2 pro?
Thanks
Old 10-28-2007, 04:56 PM
WilliamDC WilliamDC is offline
Default Re: External firewire hard drive
Thanks
Digi recomends that you plug the external hard drive into the firewire port first and then connect your mbox2 pro to the hard drive itself. I use a Lacie D2 external hard drive.
William
002R - 2ghz Intel Core 2 duo Imac - 3GB of RAM
OSX 10.6.7 - PT LE 8.0.5
http://www.pureshift.com
http://www.bsodmusic.com
Old 08-08-2008, 08:48 AM
twig twig is offline
Default
and what if mbox shuts down? does this corrupt the external?
Old 08-08-2008, 08:57 PM
Default
This is why you attach the drive to the computer firewire and the Mbox to the drive. The Mbox can crash without messing the drive. Also, if you pull the Mbox firewire cable, the drive is still connected(really important if the drive is writing data as that can corrupt the session and render it useless). I also hear that if you pull a firewire cable out of a running Mac without dismounting the drive first, you can cook the firewire port on the computer(I have done this on a PC without incident but YMMV).
Old 08-09-2008, 01:15 AM
Quicksilver Quicksilver is offline
Default
I believe a firewire 400 drive that has at least an Oxford 911 chip
Originally Posted by mtbass View Post
.....and if so, what hard drive is compatible with mbox 2 pro? Thanks
External Hard Drive Firewire 400 thekajunpimp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-13-2007 08:10 AM
What is the best firewire external hard drive!!!! ike805 Storage Subsystems 2 10-23-2005 02:29 AM
Using an External Firewire Hard drive Leon B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-02-2004 03:43 PM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
External Firewire Hard Drive.....how about this one...... jason66213 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-31-2001 12:05 AM
