Old 02-01-2019, 09:53 AM
Cavalier Cavalier is offline
Default Feeding Radio Board into Pro Tools via Mac
I've been out of the loop with regard to the interface used to get an audio feed into Pro Tools. My last experience was with Pro Tools 7.
What I used to have was xlr out of the board into a Matchbox II, then 1/4" stereo jacks coming out of there into a Digi002 rack, then firewire 1394 into my Mac tower.
I currently have Pro Tools 2018.4 on an iMac OS 10.4 with Thunderbolt 3 inputs. Same 1/4" jacks coming out of the board.
As I have read and understand it, the 002 rack will no longer work. Or does it?
What drivers and/or hardware do I need to get the audio feed into Pro Tools?
iMac (Retina 5K, 27-inch, 2017)
3.4 GHz Intel Core i5
8 GB 2400 MHz DDR4
Radeon Pro 570 4096 MB
Thank you.
Old 02-01-2019, 02:50 PM
john1192 john1192 is offline
Default Re: Feeding Radio Board into Pro Tools via Mac
8 GB 2400 MHz DDR4
Thank you.
the 003 Drivers might possibly work for you !!!
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-04-2019, 02:00 PM
It's worth a shot. Any idea how to get 1394 to thunderbolt 3? There are absolutely no adapters that go that far.
Old 02-04-2019, 03:22 PM
its2loud its2loud is online now
400–>800–>thunderbolt
It will work. Just install correct drivers. You could also use a Thunderbolt hub with FW800 on it and use 400 to 800 cable
Old 02-04-2019, 03:24 PM
Sardi Sardi is offline
FW - TB2 adapter + TB2 - TB3 adapter.
Not elegant, but it works and is the cheapest option if you can’t find a FW - TB3 adapter.
Alternatively, get a TB3 dock with FW. This will also break out to a bunch of other connectors that you may find useful. Much more expensive than the adapters though.
Old 02-04-2019, 07:14 PM
Thanks guys. I was looking into something like this. I know it's a bit steep but it's somewhat cheaper on Amazon:
https://www.startech.com/Cables/fire...er~BNDTB1394B3
Old 02-05-2019, 06:19 AM
This doesn’t make logical sense to me just to get FireWire capability. How many FireWire devices do you have?
A cable and two adapters will cost you about $60 to connect your 002.
If you’re going to spend $385 just spend a little more for a new interface and ditch the 002. Or pay a little less for the thunderbolt hub and get more use out of it.
https://eshop.macsales.com/shop/dock...E&gclsrc=aw.ds
Old 02-05-2019, 06:44 AM
Yeah don’t get that chassis.
Either get a hub that will give you loads more ports than just FW, or get the adapters.
Old 02-05-2019, 01:47 PM
Yeah was just a thought as that's it's dedicated function. Instead of daisy chaining a bunch of adapters together. But those sound more like the practical route.
ReVibe feeding back Craig F Post - Surround - Video 5 04-26-2012 10:21 AM
Pro Tools For Radio Production, Adobe Audition And Google Radio Automation... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-09-2008 07:51 PM
Lexicon AES/EBU Feeding Back? rmccam Pro Tools TDM Systems (Mac) 6 03-06-2006 05:40 PM
Feeding PT MIDI tracjk to softsynth? rpress 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-23-2002 12:48 AM
Best radio automation program for professional radio stations? GuitarEasley General Discussion 22 03-23-2002 11:32 AM
