  #31
Old 08-29-2013, 02:56 AM
mrhood mrhood is offline
Default Re: Video Engine Problems with Pro Tools 11
Still no solution for me either. I'm using Logic X while I wait for an update from Avid that will hopefully fix this.
  #32
Old 09-15-2013, 09:33 AM
AudioEngineer591 AudioEngineer591 is offline
Pro tools 11.0.2 is still a FAIL. The video is still blacked out in the grid and the videos is still blank in the external video window. AVID FIX THIS ERROR ASAP!!!!
AVID Pro Tools 12.2
Windows 10 Pro
Intel i7-4800MQ @3.7GHz
GTX870M 3GB
32GB DDR3L-1600
  #33
Old 09-17-2013, 01:26 PM
carlone carlone is offline
I was getting this exact same error. It started yesterday when I finally needed to import and playback video in a session. Tried to enable the video engine but it would give me the waiting for video engine to launch prompt and basically hang. I left and came back over an hour later and it was still frozen.
I looked online and saw these threads with no solution. Yes, I have media composer 7 installed and wasn't looking forward to doing the whole uninstall routine.
So I tried going to the USER library and deleting all pro tools related prefs including DAE, pro tools, and anything that was related. I found an AVID folder in preferences that I'd not notice before. It has some pro tools related items in it so I trashed the folder.
Restarted holding N and enabled the video engine and about 20 seconds later it open and it's been working fine.
  #34
Old 09-19-2013, 02:02 PM
Huberciczek Huberciczek is offline
First of all apologies for my English :).
Try this:
1. Launch Pro Tools
2. Go to Setup/Playback Engine
3. Choose different hardware in pop-up menu (for example from HDX to ProTools aggregate I/O - it is important to make a change)
4. Uncheck all checkboxes in Playback Engine window.
5. Enable Video Engine
6. Click OK
(Video Engine should launch properly now)
7. Go to Setup/Playback Engine again
8. Choose desired hardware and other options. If you'll find Video Engine disabled turn it on again.
9. Clik OK.
Worked fine for me.
Regards
Martin
P.S.
If someone will find it useful please post it in proper language :).
Of course this is not useful if you have AMA - related issue.
  #35
Old 09-20-2013, 03:29 AM
I've now tried 11.0.2. Same problem.
Then also tried "carlone" and "Huberciczek" suggestions but they don't work for me.
Luckily, I have Logic X which is stable as a rock and does everything I need to do.
PT 10 imports video no problem but does not have the RAM access of PT 11 and vice versa for PT 11. Crazy.
So Logic it is...
  #36
Old 09-20-2013, 11:47 AM
cut cut is offline
I removed all the plug ins in the Library > App Support > Avid >AVX2 > AMA folder and was able to load video. Of course it took my 16 x 9 clip and made it 4 x 3 so that still sucks. Now I am launching Media Compose to see the fall out. I use the same machine for both about evenly, and there is no way I want to keep dragging these guys in and out of that folder, so apparently 11 may still need some work!!
  #37
Old 09-20-2013, 12:00 PM
cut cut is offline
Yup, it completely messed up Symphony / Media Composer!!! I am dumping those app support plugs back in and relaunching Symphony 6.5 to make sure that will get that back up and running. And yes, and I was able to view XD CAM / AVC / Pro Res - so I think that is a decision those of use with 'dual use' machines have to make. Deal with the moving of app support files back and forth - drag. Avid please fix this!!! To think that there aren't people using Media Composer on the same machine as Pro Tools is a bit crazy.
  #38
Old 09-20-2013, 04:42 PM
Adman44 Adman44 is offline
I just finished installing 11.0.2 HD. I then created a new file and enabled the video engine and for the first time, it worked.
But, then I tried to import a *.mov file and got a codec error. So, apparently the issue persists.
Macbook Pro i7, 17". Dell P-650, Mackie 1402/HR824/SR1530, 002R, TLM 103, Beyer TG-X60, SM58, AKG 112/C418's/C419, TPS II, Kurzweil ME-1, DM-Pro, Pod-XT, Fender Blues Jr.
  #39
Old 09-26-2013, 07:56 PM
Stanzilla Stanzilla is offline
Hey all,
I've been having the same issue. Running a 2013 iMac that has both ProTools 11 and Media Composer 7.0 I've tried all the suggestions posted and they didn't work.
What did work was changing the install order.
We uninstalled both Media Composer and ProTools then installed ProTools First. Launched a session with video, THEN installed Media composer and the issue resolved. Both programs on the same partition and video playback works.
Weird, but effective.
-Gelman
  #40
Old 12-11-2013, 01:25 PM
pianosdr pianosdr is offline
I'm experiencing an issue with one of my computers where the video never plays back, but all audio, plugins, etc. are functioning normally. Only the video is perpetually frozen on whatever frame is shown at the selection point where I am starting the video. This frame does update when I stop playback and change my selection point, but when I hit play, it remains frozen on this screen.
Is there insight on how to correct this? This is my SiSoftware Sandra report for the problem computer:
SiSoftware Sandra
ID
Host Name : QA-W764EN-1016
Domain : **********
Computer
Model : OEM System Product Name
Serial Number : System Ser**********
Chassis : Desktop
Mainboard : ASUS P8Z68-V LE
Serial Number : MT7022K********
BIOS : AMI (OEM) 3808 05/10/2012
Total Memory : 8GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (4C 3.41GHz/3.7GHz, 3.4GHz IMC, 2x 256kB L2, 6MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : ASUS Core (Sandy Bridge) DRAM Controller 100MHz, 2x 4GB DIMM DDR3 1.33GHz 128-bit
Memory Module(s)
Memory Module : Corsair CMZ8GX3M2A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Monitor/Panel : Hewlett Packard HP ZR24w
(1920x1200, 24.0")
(1920x1200, 25.3")
Video Adapter : NVIDIA GeForce GTX 275 (240 SM4.0 1.4GHz, 896MB DDR3 2.27GHz 448-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GTX 275 (240SP 30C 1.4GHz, 896MB DDR3 2.27GHz 448-bit)
Compute Shader Processor : NVIDIA GeForce GTX 275 (240SP 1.4GHz, 896MB DDR3 2.27GHz 448-bit)
CUDA GP Processor : NVIDIA GeForce GTX 275 (240SP 30C 1.4GHz, 896MB DDR3 2.27GHz 448-bit)
Storage Devices
WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5") : 2TB (C:) (D:)
WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5") : 2TB (G:)
ASUS DVD-E818A7T a (SATA150, DVD+-R, CD-R, 198kB Cache) : N/A (E:)
Logical Storage Devices
W7 64 (C:) : 98GB (NTFS) @ WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5")
Data (D:) : 2TB (NTFS) @ WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5")
D3 Data (G:) : 2TB (NTFS) @ 2x WDC WD20EARS-00MVWB0 (2TB, RAID/SATA300, 3.5")
Optical Drive (E:) : N/A @ ASUS DVD-E818A7T a (SATA150, DVD+-R, CD-R, 198kB Cache)
Peripherals
LPC Hub Controller 1 : ASUS Cougar Point LPC Controller
LPC Legacy Controller 1 : T0 C3-33
Audio Device : ASUS Cougar Point High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Serial Port(s) : 1
Disk Controller : ASUS Cougar Point 6 port SATA AHCI Controller
USB Controller 1 : ASUS Cougar Point USB Enhanced Host Controller #2
USB Controller 2 : ASUS Cougar Point USB Enhanced Host Controller #1
USB Controller 3 : ASUS ASMedia XHCI Controller
USB Controller 4 : ASUS ASMedia XHCI Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP LaserJet P2015 Series PCL 6 (600x600, Colour)
Printer : HP Universal Printing PCL 6 (v5.7.0) (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Pro Tools 10 Video Engine failed to initialize. GXTProductions Pro Tools 10 1 12-15-2013 12:54 PM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
Pro Tools HD 8.01 Launching Video Engine fails? AMIEL Pro Tools TDM Systems (Mac) 3 10-25-2009 11:38 AM
Pro Tools 8 LE stalls at video engine launch Tommy Barth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-13-2009 01:44 PM
Where's the Video Engine? admix Post - Surround - Video 4 05-02-2008 04:51 PM
