Old 06-12-2014, 09:24 AM
Willard Willard is offline
Default C|24 Diagnose Problem of Low Thud Through Sub Output Channel 3 Only
Oops. Previously posted this in the "Control|24" forum.
I have a C|24, purchase late 2007. In the past month I’ve been getting a low pulse/thud (about 50bpm) through the sub. Here’s the details.
Channels 1 and 3 out of C|24 connected to KRK S10. Then feeding through from the KRK S10 to two KRK v6s.
I hear the low pulse/thud in the sub only.
I only hear the thud from channel three, not channel one.
Pro Tools (9) is not booted at the time.
When Pro Tools is booted, changing the volume does not change the volume of the low pulse/thud, it’s constant.
The C|24 seems to operate normally, nothing unexpected.
If I power down the C|24, I no longer hear the pulse/thud.
My guess is that it is the power supply, but would like to hear from anyone who has had similar issues or can suggest any trouble shooting I haven’t thought of.
Thanks
Pro Tools 9.0.5 | HD3 PCIe | 192 i/o | C|24
Mac Pro5,1 (mid 2010) Westmere 3.33 GHz Hexacore | 16gb ram | OS X 10.7.4 | VEPro 5.3.13141
Pro Tools 9.0.6 | HD3 PCIx | Apogee Rosetta 200 | Magma PE6R4-I
MacPro5,1 (mid 2010) Westmere 3.33 GHz Hexacore |16gb ram | OS X 10.7.4 | VEPro 5.3.13141
Old 06-12-2014, 09:29 AM
Default Re: C|24 Diagnose Problem of Low Thud Through Sub Output Channel 3 Only
I wrote to Skynet (makers of the PSU) and asked them if this sounded familiar. They said it did not, but they would diagnose my PSU for a $50 fee. That wouldn't be a problem if I was at all confident I'm heading in the right direction. Don't want to be without the C|24 if I can at all avoid it.
Old 06-12-2014, 11:28 AM
Craig F Craig F is offline
power supply I would expect to hear it in all channels
how comfortable are you opening up your unit and looking/sniffing for a damaged part
I would look at the ch3 output buffer amp back tracking to the volume control section
also look at the PSU when you have it open
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 06-12-2014, 03:52 PM
@ Craig F. Thanks for your thoughts. Essentially you're concurring with Skynet, which is helpful.
I'm very comfortable taking things apart, so I'll give that a go just to see if there's something obvious to the naked eye. I think this will likely result in my having to take it in somewhere here in LA.
C|24 Diagnose Problem of Low Thud Through Sub Output Channel 3 Only Willard ProControl, Control|24, Command|8 0 06-06-2014 03:40 PM
32 Channel Input / 16 Channel Output Device(s)? tcstx Pro Tools 9 33 02-07-2011 03:04 PM
Help Diagnose set up 1240 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-04-2007 11:43 AM
ONE BIG THUD........... gplus ICON & C|24 1 06-08-2004 06:36 AM
Kick but not thud vogue Tips & Tricks 6 04-21-2004 12:49 AM
