Old 09-03-2013, 03:05 PM
dgoodi22 dgoodi22 is offline
Default match track in Import session data window issue
weird issue:
I receive a lot ADR from studios in Europe and a few of them cause an issue when trying to match tracks upon importing the ADR into a mix session.
They both have the identical track name, being sent from and imported into an English installed version of Pro Tools , but for some reason it mixes all the names up. Can not figure out why and wondering if anyone has come across this and knows of a solution?
manually selecting 20-50 tracks per session is becoming hell.
thanks!
Old 09-03-2013, 03:19 PM
C C is offline
Default Re: match track in Import session data window issue
Are the tracks the same format?
Mono matching stereo will not work, for example.
Can you ripple the incoming tracks as a workaround? Or are the tracks in your session and the incoming session noncontiguous?
If there are two tracks named similarly/with dup1 etc appended then Pt can get confused and mismatch track names.
Anymore info you can give on either session will help track down potential issues.
C
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 09-03-2013, 03:51 PM
C
matching mono to mono and it's heavy dialog with multiple regions at specific timecode. There are no duplicates, similar or misspelled names.
if by "ripple" you mean shuffle mode, I can't move the regions as they are time specific.
Old 09-03-2013, 05:15 PM
C C is offline
No, ripple assign to tracks. If track 1 needs to match 1 and through to 50 then in import session data you can ripple the track assign by holding shift+alt+command while selecting the first destination track, the other tracks will then be assigned 1-50 (for example) like you were setting the outputs on the tracks themselves
Ceri Thomas
Personal Site
Old 09-05-2013, 01:58 PM
unfortunately the sessions don't match that way. that defeats the whole purpose of match tracks. thanks though
Old 09-06-2013, 12:35 PM
C C is offline
Could you post the main and importing sessions? no audio. Maybe theres config issue. not suggesting there is but happy to take a look and see.
Ceri Thomas
Personal Site
Import Session Data window scroll Vedat macOS 0 07-31-2012 06:28 PM
10.1.1 Import Session data window size bug? meech macOS 0 03-27-2012 09:25 AM
FR: resizable import session data window travista00 Pro Tools TDM Systems (Mac) 5 09-01-2009 05:58 AM
IMPORT SESSION DATA TRACK ORDER ISSUE s_hull 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-21-2008 05:06 AM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
