Old 02-19-2008, 02:18 AM
yazoo yazoo is offline
Default imported session data overwrites current automation!?
Hi All!
I have 2 sessions one with a "short" version of a show, and one "long" version.(They are exact copies but the short version has 1min thats cut out from the middle part)
I started mixing the short version and ended up with a result a wanted to apply to the long.
I thought that having the both session in same session should be the best way.
I used import session data from the "short" session to import the "long" and used the following settings:
* Audiomedia options - Consolidate from source media
* Trackoffsett options 02:00:00:00 (My short version starts at 01:00:00:00)
* Match Tracks
* Main playlist options - Overlay new on existing playlist
The problem is that when the new session data is imported it clears the automation from the current session.
Is there a way to do this without losing automation?
regards
benny
Old 02-19-2008, 03:03 AM
Richard Fairbanks Richard Fairbanks is offline
Default Re: imported session data overwrites current automation!?
Try it the old way. Import to new tracks (do not match tracks), cut-paste from new tracks to your destination tracks (you can do a few tracks at a time or the whole thing), delete the new tracks once they are empty.
Call me by my real name, "Postman"
Old 02-19-2008, 03:53 PM
audiograce audiograce is offline
Also,
try importing regions and media only ... disable all other options including 'Volume Automation' from the pop-up list in the import dialog.
...tg...
Warner Bros. Studios
imdb Credits
HTML code is On
Pan Link not getting imported on session import data Netto Max Pro Tools 10 2 11-11-2013 02:18 AM
Import session data from PT8 session / pan automation bad jitter Pro Tools 10 0 12-05-2011 06:17 AM
Imported session data doesn't match renumbered session bashville Post - Surround - Video 1 03-29-2011 07:24 PM
Automation overwrites data even if you do not touch anything Ale Pro Tools TDM Systems (Mac) 4 05-27-2007 06:05 PM
Import Session Data & Automation trombino Pro Tools TDM Systems (Mac) 1 10-24-2006 09:21 AM
