  #21
Old 03-26-2021, 01:40 PM
Default Re: 2021.3 firmware no options (HD Native)
Originally Posted by stevedresser83 View Post
Just ran digitest : DSI error 1171
I'm not sure if this is still the case, but historically, Digitest would always fail with 3rd party DigiLink converters attached and would only "Pass" with Avid converters attached. This was expected behavior and didn't mean that the HD or HDX cards were bad, just that DigiTest wasn't designed to run with 3rd party converters attached. Again, I'm not sure if that's the currently expected behavior, but that was always the case in the past.
Scott Gatteño
  #22
Old 03-26-2021, 02:46 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Thanks Scotty, good to know.
t
  #23
Old 03-26-2021, 09:25 PM
stevedresser83 stevedresser83 is offline
yea good to know for sure. I actually fixed the firmware update. Taking card out and putting it in a different slot is what did it. Now I'm updated but protools cannot see the burl... so still can't work but progress has been made. Gonna try and system restore again, now that the firmware issue is solved. Maybe I can get back into 2020.12 or whatever last version was that was working.
  #24
Old 03-27-2021, 01:31 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Try putting your HD card back in the slot it was at before you moved it.
I was able to update in the original slot but PT would launch than after loading a session it would play for about a minute and I would lose all audio. I would force quit and restart but the same thing continued to happened and I would get a 1174 error. I had to remove my UAD2 card from PCI-E slot 4 for my system to work again. After the firmware update HDX doesn't play nice with my UAD2 Quad installed in slot 4. I also updated my BIOS to F20d but I don't think that was the problem since PT was working for the past week or so.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
  #25
Old 03-28-2021, 03:59 PM
I ended up putting all my cards back in their original slots once the firmware update happened. Everything working over here so far
  #26
Old 03-29-2021, 11:31 AM
noah330 noah330 is offline
I'm using a chassis with my HDN card on Big Sur. Update worked fine so maybe it's a Windows issue?
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Downgrade Native firmware 10 to 9? Hugh-H Pro Tools HDX & HD Native Systems (Mac) 2 04-12-2013 09:53 AM
HD Native Firmware Flash TimNielsen macOS 5 01-29-2012 01:59 PM
HD Native Firmware error -1167 dcandusso Pro Tools HDX & HD Native Systems (Mac) 2 10-21-2011 01:23 AM
HD9 native input options Tsbnoise Pro Tools HDX & HD Native Systems (Mac) 1 03-18-2011 09:08 PM
