Old 01-25-2014, 05:27 PM
ianmiller ianmiller is offline
Default Re: eucon still bugging since maverick
The app nap suggestion definitely helps and makes it a little more stable - but only a little. Sluggish response and instability still abounds.......
Old 01-28-2014, 07:53 AM
michaiel michaiel is offline
Eucon was stable for me with 10.8, but after installing a new SSD with OS 10.9, PT 11.1 and Eucon 3.1 it is very unstable.
Hopefully AVID is on top of this.
I have never had this much trouble before....
Hackintosh
Intel Core i7-3770K Quad-Core Processor 3.5 GHz
32 Gigs RAM
UAD 2 Quad Card
UAD Duo Apollo w/Thunderbolt
Old 01-28-2014, 11:06 AM
tristan klein tristan klein is offline
Detach and Attach again on EuControl panel seems to help but the bug is coming back after 10mn.
www.tristanklein.com
Old 01-29-2014, 08:22 AM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
Interesting.
I will keep an eye on this. To me it sounds like the Apo Nap issue, but it sounds like you have done this.
Are you all running with multiple network ports active?
All on SSD boot drives?
Firewall settings?
Old 02-01-2014, 05:25 AM
Originally Posted by DanielEUCON View Post
Interesting.
Firewall settings?
Hi Daniel,
No SSD drives, no firewall, only one ethernet port active for me...
  #16
Old 02-06-2014, 06:47 AM
strangely, transport buttons always work great whatever happens...
  #17
Old 02-23-2014, 09:24 AM
is there any news here ? 3 months that I can't use my control surfaces...
  #18
Old 02-23-2014, 10:45 AM
propower propower is offline
Deleted -----
Once I disabled App nap in bth EuControl and MC_Client - things are working right so far. Will post back if this changes or degrades...
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
  #19
Old 02-25-2014, 01:58 AM
A513055 A513055 is offline
Hi, I'm having this problem too.
Turning the knobs on the MC Mix adjusts the pan (or send level) in Logic Pro, but the change is not reflected on the display of the Mix.
If I select AUX on the Mix, the display still shows Pan until I select a different track and come back. There is no way at all to get it to display the second or third AUX sends as it used to when pressing the Page button.
On the MC Control, Pressing a knob down no longer selects it for adjustment.
Basically the knobs are all broken.
  #20
Old 02-25-2014, 02:37 PM
joren joren is offline
I second this.
On my 10.9.1 system it's also very buggy:
-it often crashes on system startup, have to launch it again.
-it often crashes upon connection with Artist Mix.
-mostly the controller is auto-connected, but every once in a while I have to add it manually.
-it often holds up system shutdown. I have to do shutdown command again then it continues. When I disable Eucon apps in preferences, it doesn't happen anymore.
-ONLY PORTS 1-4 ARE USABLE IN MAC OR HUI APPS!!! This means I can have only one app listed in the EUCON Prefpane, and have to reboot every time I want to change that. Extra ports don't get created in audio midi setup.
-it often seems to introduce some delay.
All of this is on an absolutely fresh install of mavericks. Very annoying for a fine product like this.
PLEASE AVID, fix this. Should be done by now.
Mac Pro 8 core OSX Mojave
PT10HD, PT11HD, PT12HD Native
3x Avid Artist Mix, Euphonix MC Transport, PT|Control
Maverick with Pro Tools LE 8.0.5 goose22j 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 12-03-2014 09:18 AM
Maverick & protools 11 mgsr70 Pro Tools 11 7 01-25-2014 05:06 PM
Digidesign 002 and OSX Maverick 67Thunderbird Digidesign Hardware & Software 0 11-27-2013 04:58 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
cs3 still bugging the hell out of me midnightrambler Pro Tools TDM Systems (Mac) 6 06-11-2009 09:39 AM
