PT 8 Not Clearing DSP
Since PT 8 sessions when shut down then you open another session or the same session again will not play i get DAE 6031 when the transport in pressed into play mode and the system usage window never clears it self when a session is shut down.I half to close protools and reopen it for any session big or small or brand new to play again.Why?This never happened in any version before on XP.I have screen shot i can show but images are turned off on my account can you turn it on so i can show them.
Phil Windows Vista Intel quad core 2.5 4 gigs ram HD 3 plus core accel 2 process cards 192 IO 96 IO |
Re: PT 8 Not Clearing DSP
try turning off DSP cache in the system usage window.
Hi Phil, You might try to go to your system usage window and diable the DSP cache and clear cache. Restart PT and see if it helps.
Looks like Brandon beat me to it!!!
https://www.thirdeyerecording.com/ Last edited by Third Eye Studios; 01-12-2010 at 08:50 AM. Reason: oops |
Where is this option i can not see it.I'm on a windows based machine not a mac?
I've never seen this option sorry for being not aware of this. |
Looking at your picture. On your HD Process #1 card (the bottom one in the System usage view) there is a little arrow. Click on that.
This option was added with PT8. I only use it during tracking sessions that all use the same configuration. It can speed things up when jumping from session to session. I turn it off otherwise.
https://www.thirdeyerecording.com/ |
Thanks
I totally missed it.What a tool i am.I wish they would make it clear when they do thing like this.Will see if it helps if not any other tips? Phil |
That should work, I don't know of what else to suggest at this time.
It clears the cashe DSP window but the sessions don't play 6031 errors.If i close protools and reopen it the session work fine what bull [bleep][bleep][bleep][bleep].I wish they never changed this stuff 7.4 was rock solid!Maybe tech support will chime in?
I thought i would include this.
PC Wizard 2010 Version 1.92 ------------------------------------------------------------------------------------------ Owner: Protools User: Protools Operating System: Windows Vista (TM) Ultimate Professional 6.00.6001 Service Pack 1 Report Date: Tuesday 12 January 2010 at 12:37 ------------------------------------------------------------------------------------------ <<< System Summary >>> > Mainboard : Asus P5WDG2 WS Pro > Chipset : Intel i975X > Processor : Intel Core 2 Quad Q9300 @ 2500 MHz > Physical Memory : 4096 MB (4 x 1024 DDR2-SDRAM ) > Video Card : ATI Radeon HD 3800 Series > Hard Disk : Maxtor (251 GB) > Hard Disk : Maxtor (251 GB) > Hard Disk : ST3320620AS (320 GB) > Hard Disk : ST3500410AS (500 GB) > DVD-Rom Drive : Optiarc DVD RW AD-7200S SCSI CdRom Device > DVD-Rom Drive : Optiarc DVD RW AD-7200S SCSI CdRom Device > Monitor Type : WESTINGHOUSE - 45 inches > Network Card : MV88SE614x PCIe to SATA2 controller Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller (Copper) > Network Card : MV88SE614x PCIe to SATA2 controller Yukon 88E8052 PCIe ASF Gigabit Ethernet Controller > Operating System : Windows Vista (TM) Ultimate Professional 6.00.6001 Service Pack 1 > DirectX : Version 10.0 > Windows Performance Index : 5.9 |
Clearing All Automation? | Jon_Atkinson | macOS | 3 | 03-07-2014 11:58 PM |
Clearing preferences | dedwards | Pro Tools TDM Systems (Mac) | 1 | 12-14-2010 11:10 AM |
Clearing Groups | acorbeth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-03-2010 08:31 AM |
Clearing Ext Drive | drummer9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-03-2009 03:54 PM |
Clearing automation | gh4life | Pro Tools M-Powered (Win) | 2 | 07-19-2006 10:50 AM |
