Time signature change
I'm writing a score and I'm slaving Reason along through Rewire but can't seem to get it to follow time signature changes. Does ReWire support this? It seems to be a ProTools problem, as the beat clock in Reason starts to freak out a bit before the actual time signature change. I'm running 6.9.3 csyadda on 10.4.7. Thanks for the input!
Tracey |
Re: Time signature change
Hi Tracey,
I also use Reason and have the same problem... It seems that on the time sig. Reason turns all the sequence into the new Time sig. and therefor all bars, bars nr, ect gets incorrect. Unfortunately, there is no solution : the problem comes from Reason uncapebility to change signature. Either do 2 songs, either keep the first Time sig. and work with it....or either forget Reason as a sequencer. I must say I love Reason on my labtop to quickly put ideas, but it is a very bad sequencer...ProTools's sequencer is not already good enough and I'm still waiting... Come on Digi work on your MIDI sequencer a bit more! Good luck --------------------- Powermac G4 1,25GHZ 768 MB Ram ProTools HD2 7 Reason 3 Hate for Logic! (gave me grey hairs)
MacPro 2,66 GHZ 4GB Ram ProTools HD2 7.3.1 cs5 Logic Pro 8 Reason 4 Ableton Live 6 |
what are you using reason for? the samplers? the Rex player? What version of reason?
Ray Trujillo Freelance Audio Engineer |
I'm using it for Combinator, Redrum and Dr Rex, etc. It's version 3.0.5. And yes, I know I can sequence out of PT into Reason. Wasssup Ray?
Reason 5 Time Signature Change Problems | thequantumwombat | macOS | 0 | 02-24-2014 08:51 PM |
Time Signature change in Pro Tools | phefner84 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-16-2011 05:31 PM |
Pro Tools/Reason Time Signature Change Q | citychalkoutline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-12-2009 09:00 PM |
How to change MIDI time signature | dr166006 | MIDI | 6 | 03-31-2009 04:19 PM |
how do you change the time signature? | jordan_ellipsis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-11-2007 06:22 AM |
