Old 07-27-2017, 05:27 PM
Sid0 Sid0 is offline
Default Compose in Cubase and Bounce Audio In Pro Tools
I am composing / sequencing in cubase. How can I press play in Cubase and have the audio bounce in Pro Tools 12. Thank you
I know this have to be done via Lan. I am connected via LAN Ethernet Cable
Old 07-27-2017, 05:55 PM
Why? Just getting "a bounce" in Pro Tools means nothing. You can record the same final output (e.g. stereo mixdown) in Cubase. I suspect 'bounce' is not what you really mean. What exactly are you trying to do and why?
Old 07-27-2017, 07:48 PM
Default Re: Compose in Cubase and Bounce Audio In Pro Tools
I don't want to bounce in Cubase. I want to route the audio to bounce in Pro Tools. I am using a host and slave system. I will be mixing in Pro Tools.
Old 07-27-2017, 09:22 PM
There is no easy way to do this. You are dealing with two DAWs that AFAIK are Rewire Master only, no slave support. So mix in Cubase, or find equivalent AAX VI Plugins for Pro Tools, or host your VST VIs in something that supports being a Rewire Slave, like Ableton Live. Or just bounce the audio out of Cubase and manually move to Pro Tools.
Old 07-27-2017, 10:25 PM
There is a way to do this. All film composers have this set up. They work with Cubase (Master) and Pro Tools (slave). They route the audio to pro tools so it can bounce/ print there to save time for exporting / importing
Old 07-28-2017, 12:54 AM
If you know it can be done, and you know how then surely you just open up the documentation for Pro Tools that describes how to make it a ReWire slave.... or since *all* composers are doing this you must be able to just Google for instructions that would be all over the web...
Ableton Live, Reason, VE Pro.... different story as they slave to Pro Tools via ReWire.
Old 07-28-2017, 09:09 AM
lemix's Avatar
lemix lemix is offline
OK, allow me describe how I do similar tasks...if I really understand what the OP is asking ;
I work 90% in Nuendo, and occasionally need to mix in PT for client request reasons . Yes, I do post for broadcast TV..
* all my work is done in Nuendo . Then I am exporting AAF including all raw audio tracks and their after edit/processed version. File naming and management is important !
* import AAF into PT and mix out final and stems.
I find it a logical, solid way to work. although a bit time consuming ( bill your client )
I hope this makes sense and help you out a bit...
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 07-28-2017, 05:28 PM
Thank you all for your input. All great feedback but still does give me any answers. I appreciate it.
Perhaps I should try the cubase forum.
Old 08-01-2017, 03:56 PM
justDoug justDoug is offline
If you find your answer, please share it here...!
Sent from my ASUS ZenFone 2E using Tapatalk
Old 08-01-2017, 06:07 PM
Don't hold your breath.
What exactly are you trying to achieve/solve? You can do a lot by connecting Pro Tools up to software like Ableton Live or VEP. And since it is actually doable folks here can help you out with that.
Best way to compose beats in Pro Tools? saltydeath 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-11-2013 10:01 AM
How many people would love to compose using Pro Tools but can't due to crashes? Caatalyst Windows 17 08-10-2012 12:53 PM
Any reason not to compose in pull-down? StuThomas Pro Tools TDM Systems (Mac) 2 01-31-2006 06:58 PM
Why can't I export PT audio like Cubase? Bounce Q Johnny916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 25 07-16-2004 08:46 PM
pro tools audio to cubase? oki General Discussion 4 11-29-2001 09:29 AM
