Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
#31
![]() Quote:
#32
![]() Quote:
#33
We've got two M10s with 24 faders as four fader modules and the master module is on the right side. I guess I'm in a special situation as we also do live broadcast with the S6s.
Layouts, spill zone and the spill L or R feature is very essential for us. If I need something quickly, I usually use the attention key on the VCA to get things to the spill zone. If I need to have something in front of me but would still need something, I whether use the spill L&R or a duplicate layout with few modifications to the original. - Virtual layouts would help me greatly. For instance if I could assign more than 24 channels to one layout and bank in the layouts. - Adding more knowledge to Flip would be great. I'm already happy to have it, but it'd be great if I could select what I need to flip and then flip it to the faders. - Is there any chance that third party plugin developers would be able to implement curves on the master module just as Avid's channel strip, Pro Comp, etc. have? - Maybe I can't really describe this properly, but I'd like to see some kind of temp group feature, where I could link/group tracks so their parameters, plugin adjustment would be temporary linked. You can see this in some live consoles and this very convenient.
my blog:Tamas Dragon |
#34
![]() Quote:
Thanks for the response. Glad at least some of that stuff is on it's way. Hopefully you and all the other Avid S6 guys will consider the rest as well! As for the layouts, I'm running an M40-16-5D* system and the two layouts I'm referring to set all 16 faders to the same tracks but with two different process/knob module settings. I just traded up from an M10-8-5 system with similar 8 fader layouts that didn't have this issue. Would it help if I sent you the two layout files? If so, please let me know where to send them. Glad to help any way I can. Thanks, Russ * for what it's worth, back to the general topic: I have 8-fader/process/knob modules on either side of the MM/AM center section. I generally use two basic workflows. One is VCAs on the left, selected spills on the right (alla the Mick Guzauski approach he describes in his Avid video interview, except of course I have to page through anything greater than an 8 fader group so the recent addition of the ability to page within spills was very valuable) and the other, simply paging through sessions 16 fader banks at a time. In this case I either expand per track and process (or "local" VCA spill) as needed or leave things un-expanded when working on more than one track/process simultaneously (which I often do). I never use the new auto knob module assign function, probably because I only have two knob modules and they're always already being used for something per the above. Last edited by rus5; 02-09-2016 at 02:47 PM. |
#35
![]() Quote:
Virtual Layouts are being worked on as Eddie mentioned. That is when you start making layouts which exceed the number of physical faders on your S6. We have worked and are always willing to work with 3rd parties to add support for plots. So far you can see plots on 3rd party products from Sonnox, McDSP, and Fabfilter off the top of my head. Please encourage the particular plug-in manufacturer to connect with Avid developer services so we can help facilitate better pagetables and support for plots on EQ and DYN products. Jeff
Jeff Komar Applications Specialist, Pro Audio Avid |
#36
![]() Quote:
#37
![]() Quote:
#38
Interesting! I would find that very useful. I frequently have to write plugin automation, then copy it down to one or more channels. I would like to be able to temporarily 'gang' together parameters between two channels and write them at the same time, while only physically changing one channel at that moment.
Pro Tools HD 12, HDX3 & MTRX + HD MADI MacPro 2.4 12-core, OSX 10.12 HP Z230 Hackintosh, RME MADI S6 M10 16-5 w/ producer desk AJA Kona LHi, Sync HD www.ToolshedAudioPost.com |
#39
Lucien, you can gang multiple channels' plugin controls. Just make a group & select which slots or sends you want to gang.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.11.6 / Pro Tools HD 12.6.1 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V3.6 ~ ~ MBP 15" 2.8 Intel Core i7 -10.12.5 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.6.1 - UAD2 V8 / UAD2 Satellite DUO ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG |
#40
![]() Quote:
True, but setting that up is slower than copying plugin automation from one track to another. Using groups makes a lot of sense if the tracks need to be linked over a long period of time. But I was thinking of something fast for making a quick adjustment over a single sound effect that may have parts in multiple tracks. Honestly, it sounded like a cool idea at first, but the more I think about it, the more I realize that I would use a feature like that very infrequently. Still a cool idea, but I'll be putting that at the bottom of my wish list.
11R and EZ workflow | Fezzler | Eleven Rack | 13 | 03-15-2015 02:18 PM |
Workflow: Creating Film score music (template/setup/workflow) | jhonny.eriksson | Tips & Tricks | 5 | 03-03-2015 10:08 AM |
Workflow | pinnacle | Pro Tools 10 | 6 | 06-22-2012 10:01 PM |
MXF Workflow Help! | legasafe | Post - Surround - Video | 2 | 02-25-2011 06:40 AM |
Workflow! | kje | Tips & Tricks | 11 | 06-26-2010 08:15 PM |
