Re: Double problem - M-Audio Fast Track Ultra 8R
Not if he goes and properly set the sound playback and the properties tab for windows as I pointed out. This way windows is defaulted to use the interface and will use it with the right bit and sampling as the interface is set, which is mostly the reasons for glitches as people do not tend to set those right. Back in the days when I had a fast track, I would do these and had 0 problem playing windows and other programs sounds through the fast track.
Unfortunately, Windows will change these settings at will. And Protools then can't override them.
For example, pop in a CD and watch the sample rate setting change to 44.1. Then open a PT session at 48 and you get an error. Manually resetting the Windows setting does fix the problem but you might have to do it all the time. Setting the default device to something other than the one being used for ProTools solves the problem and the setting never clash. Until Windows/Motherboard changes the default device! Arghhh! BTW I only had this problem in Windows 7. Windows XP did not behave this way on the same exact computer/hardware.
DC-Choppah's Project Studio: ASUS PRIME Z390-A / Intel i7 rackmount PC Windows 10 home 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle Tascam US-16x08 Interface 100% Analog real time monitoring 16x4 Yamaha 16 channel MG16XU Analog Monitor Mixer Yamaha MX-88 / Novation XiO keyboards Mackie 4-channel headphone amp Adam A8X monitors Blue / Shure, etc. microphones Estonia 6' 8" Parlor Grand Piano Yamaha Studio Drum kit https://www.dc-choppah.com/ |
That means that either:
Whatever software/driver you used to play the audio on the CD was smart enough to remember the state of the Windows audio software device and set it back after it was done. Just a few lines of code that make all the difference! or, Windows is doing a software re-sample to adjust the CD audio to whatever the interface was set for. More detail here: http://social.msdn.microsoft.com/For...diodevelopment But Windows 7 won't change the sample rate of the hardware audio interface to match the audio signal (like Windows XP used to). Meanwhile, if one does NOT set the interface as default, then windows does not have control over it and PT is free to adjust its sample rate as it wants and so the two do not clash. When set as default, PT cannot override the windows settings.
M-Audio Fast Track Ultra Help! | Szenasi | FireWire & USB Audio Interfaces (Win) | 2 | 05-26-2013 11:55 AM |
5.1 with M-Audio Fast Track Ultra 8R | Elby | Post - Surround - Video | 3 | 05-25-2012 08:43 AM |
Pro Tools LE and M-audio Fast track Ultra | howbotnik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-16-2011 02:56 PM |
M-Powered 7.4 and M-Audio Fast Track Ultra | taveren93hgk | Pro Tools M-Powered (Win) | 3 | 04-29-2009 10:21 AM |
Fast Track Ultra problem | drhum23 | Pro Tools M-Powered (Win) | 1 | 08-01-2008 11:56 AM |
