Post house Mac -> PC
Our post facility (5 Media Composer edit suites, 2 PT audio suites) will likely be converting over from Mac Pros to HP Z8s.
If there are others who have gone through this process, I would love to know about any unexpected issues that may have come up as you switched Pro Tools over to PC in a post production environment. We share central Avid storage, and sequences are shared through Interplay. Thank you for any insights!
dpkaufman.com |
Re: Post house Mac -> PC
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Hey Doug,
These days PT and MC run pretty much the same on PC and Mac. As Brandon said the keyboard shortcuts are the main adjustment. Also window management under Windows is inferior compared to Mac. For multiple displays you have to stretch the main parent window across both, then you can arrange the Edit and Mix windows. Window configurations are your friend. Other OS differences abound obviously but I bounce back and forth between the two and PT is fairly equal.
~Will |
Also it will be an adjustment for IT. But that shouldn't be an issue.
The HP Z series are fantastic workstations.
~Will |
Hello,
I echo the above comments - it's a mostly fine transition. Often slightly more performance with a high-spec win system but nothing outrageous. The largest issue as smurfyou mentioned is window management - if you're used to moving individual windows anywhere it's confusing at first but you deal with it. The largest issue for us is pipeline - keep in mind all the places you get sessions and files from. You mentioned Avid storage, that's interchangeable as you know. However if folks deliver a lot on HFS+ you'll need to get some workflows going. There are utilities to read/write mac volumes in windows but don't run a session from them. Allow time to adjust, it's weirdly different but fine. Hugh |
I have found that some plugins are not "cross-OS compatible"... meaning that you loose parameters and automation going from one OS to another.
Manu PT Ultimate - Mac Studio M1 Max - Monterey - RME Fireface UFX II - 2x S1, 1x Dock with an iPad 7th gen - Genelec 8330 5.1 setup |
Which plug ins? I haven't run into them but I don't use any exotic plug ins.
For all talking about the way pro tools on windows works with edit and mix windows. Yes it's not the best. I just use one display for pro tools and a small display for plug in window.
While I happen to prefer windows, a huge amount of tomorrow's post is going to be Dolby Atmos and it is Mac-only so far.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
That's not true at all. The RMU doesn't care if you are windows are mac. PT acts the same for both. If you want an all in one solution, You can run the RMU on the same computer as PT. The only thing you don't get is the atmos bridge. I think it has too many problems anyway.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme Last edited by Brandonx1; 02-25-2020 at 07:45 AM. |
Post house upgrades to 11? | Markk | Post - Surround - Video | 38 | 05-28-2013 12:54 AM |
Audio Post House in DC | jraabe | Post - Surround - Video | 5 | 04-30-2010 06:31 AM |
post production house | manis | Post - Surround - Video | 5 | 07-21-2007 07:55 PM |
post house telecommunications questions | marty lester | Post - Surround - Video | 2 | 07-05-2007 05:51 AM |
Post audio rental house | johnnyreno | Post - Surround - Video | 3 | 04-12-2007 05:15 PM |
