Old 02-24-2007, 11:41 AM
skylab001 skylab001 is offline
Default Multi Processor RTAS support
I have just read that this is possible in 7.1 and 7.3 of PT LE, but I don't have a multi processor machine yet so I was wondering.....
A. How well it works
B. How many processors can be used? (ie. on the new quad core intels how many chips can be used....3 at 99%)
C. Will this support the 8 core processors? (like the rumored 8 processor macs when they arrive)
Old 02-24-2007, 12:26 PM
twix twix is offline
Default Re: Multi Processor RTAS support
My setup is as follows
-G5 quad core 2.5ghz
-4GB DDR2 SDRAM
-002R
-LaCie External 250GB FW800 HD
-Protools 7.1
-Mac OSX 10.4.8
I have always worked on HD systems so this is my first 002/LE setup. I am really happy with how many tracks and plugins i can run on a sessions. I usually record at 96k, when it comes time to mix i save copy as.. and convert everything to 48k. I have no problems running 48tracks with ALOT of plugins, mostly waves stuff. I keep an eye on my system usage meter as well. I don't run CPU heavy plugins like BFD or some of the mastering stuff like L2, LinMB, Lineq or Maxim, they also induce alot of delay. When i do start running into CPU overload, I will run audiosuite on some stuff.
This is my playback engine settings (found this works the best).
-H/W Buffer size (1024)
-RTAS Processors (1) <--- no idea why it works the best
-CPU Usage limit (99%)
DAE Playback buffer (2) or (4)
Hope this helps.
Old 02-24-2007, 05:41 PM
Really so this multi processor support really doesn't work well? I'd think with a quad core mac you at least be able to use 2 of the 4 processors for plugs. Maybe I'm misunderstanding how it works.
48 tracks at 96K or 48K? So do you think your LE system compares to an HD1/HD2 system with the quad core mac?
Old 02-24-2007, 06:52 PM
accession accession is offline
Are you suggesting that recording at 96k-converted-to-48k sounds better than native 48k?
Old 02-24-2007, 07:29 PM
sorry thats a typo, i meant to put 2 down for the cpus. If i select 3 or 4 it just gives me errors. I feel i can do what i need to do with the g5 LE system. That's 48tracks at 48k. I can run 48 tracks at 96k but with no where near the plugs. As far as LE/002 compared to an HD|1 or HD|2, well HD is just alot better, and if i had to money to spend, i would rather have an HD|2, lol.
The reason i record at 96k is that it gives me the option to take the material elsewhere and mix on an HD system with an SSL.
Old 02-24-2007, 08:46 PM
CV CV is offline
http://duc.digidesign.com/showflat.p...fpart=1#917507
for high latency ( large buffer) mix sessions it runs fine
For low latency ( small buffer) you cannot run more than 2 of the multiple processors. Pro Tools LE does not do proper "multi threading"
it basically doesn't take full advantage of the cpu's power.
This means if you want to use a big sessions with a couple virtual instruments at a low "playable" latency level, look for another DAW.
HD and Kontakt question - multi processor support DrFord Pro Tools TDM Systems (Mac) 5 09-21-2010 02:37 AM
Kontakt 3.5 beta with rtas multi-processor support tonwurm Virtual Instruments 1 06-08-2009 10:39 AM
PTLE 7 & multi-processor support jlcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-09-2005 03:07 PM
HTDM and Multi processor support houser Pro Tools TDM Systems (Mac) 1 08-08-2002 01:00 AM
Will HD for Windows support multi-processor? tonygoodall Pro Tools TDM Systems (Win) 0 03-15-2002 04:36 PM
