Old 01-30-2002, 09:17 AM
j20056 j20056 is offline
Default More than 5 inserts in serial for chain of effects - How?
I just ordered Waves. As a guitarist, I own about 15 stomp boxes, and some rack gear, and the signal chain can be lengthy.
By switching to Waves, I want to use the digital effects (and do some tweaking to reproduce some of the vintage pedals we all adore) and create a similar chain.
Now, ProTools LE only has 5 inserts per channel, but I would like to do possibly more than that in serial.
So I was thinking to do the following:
1. Create a mono audio track for my guitar.
2. Create 3 Aux channels, and have the input of the second one come from the output of the first one, and same for 2 and 3. I could then have as many as 15 effects in serial.
To be funkier, I could probably do some parallel stuff as well, but not sure how?
Has anyone experimented with this, and more importantly, what solution creates the least amount of noise?
Digi002 Rack
Mac Pro 8-core 3Ghz
8gb RAM
3X 500GB 7,200 SATA DRIVES
OSX 10.5.7
PTLE 8.0cs3
Old 01-30-2002, 09:26 AM
yavuzj yavuzj is offline
Default Re: More than 5 inserts in serial for chain of effects - How?
3 Auxs should work but if you record the ending signal they get recorded.
However, if you create 2 audio channels for recording the same signal and get 1 of the inputs to record the ending signal from 3 auxs and the other directly from input, you can change things later. [img]images/icons/smile.gif[/img]
Yavuz AKYAZICI
Guitar Player, Composer
http://cdbaby.com/cd/volcano
http://volcanojazz.com
http://myspace.com/volcanojazz
Are mixer inserts used sequentially in a signal chain? illution1 Pro Tools 10 1 01-28-2014 01:58 PM
Effects Chain Soundtrack2life Pro Tools TDM Systems (Mac) 5 01-03-2009 07:28 PM
Effects Chain Question FMCPete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-28-2004 02:54 AM
Can you daisy chain S/PDIF outboard effects units? Pako 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-08-2002 11:45 AM
guitar effects chain - preferences? pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-26-2002 07:37 AM
