Re: 3rd Monitor Choice / Audio for Picture
The video playback is separate from the Pro Tools/Mac/Windows UI. There's never a risk of moving the video window or having a mouse drift across the frame while clients are in the room. ADDITIONAL benefits: -Playback is smoother and tighter than it is on the desktop UI. -Your TV is actually running at the frame rate of the video. -You can mult the signal (such as an ADR booth, etc.) with standard issue HDMI or SDI hardware. I emailed AJA and asked why the T-Tap is not listed as being Pro Tools compatible. Turns out that Avid changed the compatibility guidelines to only include devices that are capable of external genlock. Having tested the T-Tap many times with SynCheck, I've come to the conclusion that it's plenty tight, and that genlock isn't necessary for most of my workflows.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
Thanks! Sounds great and like a good value for the money.
On my current setup i'm experiencing the video on a 4k TV (connected directly to a Mac 6.1 D-300 via HDMI) being a little bit unsync, so that i put he "Video Sync Offset" on PT to around 20 quarter frames. Do you think the T-Tab could help here?
Béla Brandes | www.bbsounddesign.de |
(If you need 4k, you should go to a Kona PCIe card, but I don't think many audio post places bother with 4k)
No, actually i don't need a 4k resolution. It's just, that it is now the display being installed in my edit suite. :-/
Do you have a tip of how measure the exact amount of offset, since the "catchin' sync" App does not seem to available in the german app store?
https://sync-one2.harkwood.co.uk Without hardware or an app, you could download the Sync One 2 videos and then shoot your system with an iPhone set to high frame rate recording. Drag that into a video editor and put it under the scope. Make sense? It won't do everything that Sync One 2 will do, but it will at least get your system tighter. I'm not a video technician, but I believe that's how TV stations used to do it.
#16
Yes, filming your system and closely checking in a video editing tool, is pretty much the same thing like the catchin sync app does. Good idea! Thank you.
#17
What also seems to work, is taking a photo from the print in TC in video Refference and the TC counter on PT Main Screen while it runs. It doesn't allow you to measure sub-frame differences, but you'll be able to get quite close.
who uses picture monitor for plugins etc? | The Cargo Cult | Post - Surround - Video | 17 | 05-09-2013 04:36 PM |
need a little help making monitor choice | x9blade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 04-11-2006 11:46 PM |
Audio Workflow with picture changes?? | dcaudio | Post - Surround - Video | 9 | 08-18-2004 06:54 PM |
Playing to Picture on seperate monitor or TV | Ronnisi | Pro Tools TDM Systems (Mac) | 15 | 09-02-2003 07:51 PM |
active vs passive monitors? monitor choice? | isolde | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-12-2002 07:01 AM |
