\"Channel Matrix\" acting up
Lately our channel matrix section of our procontrol main unit has been acting intermitantly. We typically run the channel matrix in view mode and for a year we have not had any problems.
Now, the matrix keys will simply stop functioning during a session. Jogging the unit in the ethernet controllers page under the peripherals menu helps temporarily, as does trashing the digiprefs or resetting the firmware. But the problem comes back within a few hours. Is there anything else I can try (short of reinstalling ProTools)? The fact that we can "fix" it by jogging software settings makes me think that this is not a hardware problem, but I can't be sure. Any suggestions? |
Re: \"Channel Matrix\" acting up
I still haven't been able to figure this out. Has anyone else even seen this (or something similar).
I have to disable the ethernet controllers and re-assign them at least once a day. |
This problem seems to be getting worse. It used to creep up only after closing one session and opening another. Recently it's been happening throughout the course of a session. We can still get functionality back by unassigning the main unit and then reassigning it, but I end up going through the motions 5 or 6 times a day. I've tried reseting the firmware with no effect.
Anyone? |
I have a problem that seems alike...
Whenever I work on smaller projects ( 16 fader or less) I disable my two outer faderpacks. When I do this my channelmatrix becomes dead. I can't select,enable,disable or edit any group or channel. The only thing thast solves the problem is reloading the session. It's a 6.4 (whateverCS)problem |
Let's keep this topic on top of the list
We'll wake them up ( hopefully...) |
AND DIGIDESIGN STILL KEEPS QUIET...... no reaction...no response...the phone is dead...the procontrol seems obsolete...
Digi...please fix the lost of channel Matrix in PT8 | vudoo | ProControl, Control|24, Command|8 | 33 | 12-12-2009 02:46 AM |
Channel matrix fixed in 8 | Pete Gates | ProControl, Control|24, Command|8 | 4 | 11-12-2009 03:32 PM |
Anyone here using PT8 and Procontrol with no loss of Channel Matrix ?? | vudoo | Pro Tools TDM Systems (Win) | 10 | 04-24-2009 07:31 PM |
Loss of Channel Matrix in PT8 | maxtn | ProControl, Control|24, Command|8 | 8 | 03-28-2009 09:14 AM |
Channel Matrix on Pro Control | Armando | Pro Tools TDM Systems (Mac) | 7 | 07-12-2002 06:54 AM |
