MobilePre reboot (DRIVER_IRQL_NOT_LESS_OR_EQUAL (MAudioMobilPrell.sys)
Hi ! Since i'm working on my laptop now, i'm producing music with a M-Audio Mobile Pre audio card. The sampling frequency is the same as my laptop audio card (44.1) so there is no disconnection or everything. So, it works well, except that sometimes (maybe everyday) the PC reboot with a blue screen saying something like "your computer got a problem etc" and the error code is : "DRIVER_IRQL_NOT_LESS_OR_EQUAL (MAudioMobilPrell.sys)". Do you know what i should do to stop having this ? (i often produce and do something else at the same time, on my computer, could that be why ?) Also, is this harmfull for my laptop ? THanks a lot ! (i want to join a pictures but i cant right ?) SiSoftware Sandra ID Nom de l'Hôte : KyuriPort Groupe de Travail : WORKGROUP Système Modèle : ASUS GL552JX Numéro de Série : F6N0CV3******** Chassis Système : ASUS Ordinateur de Poche Carte mère : ASUS GL552JX Numéro de Série : BSN1234567********** BIOS Système : AMI (OEM) GL552JX.204 04/20/2015 vPro Intel : 9.00.30.1482 Mémoire Totale : 7.9Go DDR3 SO-DIMM Processeurs Processeur : Intel(R) Core(TM) i5-4200H CPU @ 2.80GHz (2C 4T 3.39GHz, 3.4GHz IMC, 2x 256ko L2, 3Mo L3) Prise/Connecteur : FC PGA947 (G3) Chipset Contrôleur de Mémoire : ASUS Core (Haswell) DRAM Controller 100MHz, 2x 4Go DDR3 SO-DIMM 1.6GHz 128-bit, Graphiques Internes Module(s) de Mémoire Module de Mémoire : Hynix (Hyundai) HMT451S6BFR8A-PB 4Go DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Module de Mémoire : Hynix (Hyundai) HMT451S6BFR8A-PB 4Go DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Système Vidéo Moniteur : ChiMei Moniteur Plug-and-Play générique (1920x1080, N156HGE-EAB , 15.5") Adaptateur Vidéo : Intel(R) HD Graphics 4600 (20CU 160SP SM5.0 600MHz/1.15GHz, 512ko L2, 2Go DDR3 1.6GHz 128-bit, Graphiques Internes) Processeurs Graphiques Processeur CUDA : nVidia GeForce GTX 950M (640SP 5C 1.12GHz, 2Mo L2, 2Go 1.8GHz 128-bit) Processeur OpenCL : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.15GHz, 256ko L2, 2Go DDR3 1.6GHz 128-bit, Graphiques Internes) Processeur OpenCL : nVidia GeForce GTX 950M (640SP 5C 1.12GHz, 80ko L2, 2Go) Processeur Compute Shader : NVIDIA GeForce GTX 950M (2Go) Processeur Compute Shader : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.15GHz, 512ko L2, 128Mo DDR3 1.6GHz 128-bit, Graphiques Internes) Processeur OpenGL : GeForce GTX 950M/PCIe/SSE2 (2Go) Dispositifs de Stockage Physiques HGST HTS541010A9E680 (1To, SATA600, 2.5", 5400rpm, 8Mo Cache) : 932Go (D:) (E:) Micron_M600_MTFDDAV128MBF (128Go, SATA600, M.2, SSD) : 119Go (C:) HL-DT-ST DVDRAM GUC0N (SATA150, DVD+-RW, CD-RW, 512ko Cache) : N/A (F:) Dispositifs de Stockage Logiques MUSIC (D:) : 466Go (NTFS, 4ko) @ HGST HTS541010A9E680 (1To, SATA600, 2.5", 5400rpm, 8Mo Cache) A-Dream (E:) : 466Go (NTFS, 4ko) @ HGST HTS541010A9E680 (1To, SATA600, 2.5", 5400rpm, 8Mo Cache) OS (C:) : 119Go (NTFS, 4ko) @ Micron_M600_MTFDDAV128MBF (128Go, SATA600, M.2, SSD) Disque Dur : 451Mo (NTFS, 4ko) @ Micron_M600_MTFDDAV128MBF (128Go, SATA600, M.2, SSD) CD-ROM/DVD (F:) : N/A @ HL-DT-ST DVDRAM GUC0N (SATA150, DVD+-RW, CD-RW, 512ko Cache) Périphériques Contrôleur Hub LPC 1 : ASUS Lynx Point LPC Controller Périphérique Audio : ASUS Lynx Point HD Audio Controller Codec Audio : Conexant 510F Contrôleur de Disque : ASUS Lynx Point 6-Port SATA AHCI Controller Contrôleur USB 1 : ASUS Lynx Point USB xHCI Host Controller Contrôleur USB 2 : ASUS Lynx Point USB Enhanced Host Controller #2 Contrôleur USB 3 : ASUS Lynx Point USB Enhanced Host Controller #1 Contrôleur SMBus Système 1 : Intel ICH SMBus Imprimantes et Fax Imprimante : Microsoft XPS Document Writer v4 (600x600, Rendu des Couleurs) Imprimante : Microsoft Print To PDF (600x600, Rendu des Couleurs) Imprimante : Foxit PhantomPDF Printer Driver (300x300, Rendu des Couleurs) Fax : Microsoft Shared Fax Driver (200x200) Imprimante : Canon Inkjet Type4 Class Driver (600x600, Rendu des Couleurs) Services Réseau Adaptateur(s) Réseau(x) : TAP-Windows Adapter V9 (Ethernet) Adaptateur(s) Réseau(x) : Realtek PCIe GBE Family Controller (Ethernet) Adaptateur(s) Réseau(x) : Bluetooth Device (Personal Area Network) (Ethernet) Adaptateur Sans Fil : Intel(R) Dual Band Wireless-AC 7265 (802.11g (ERP), WEP n-bit, 54Mbps) Gestion de l'Énergie Batterie Nbre. 1 : ASUSTeK GL552JX 48.00Wh/3.20Ah Système(s) d'Exploitation Système Windows : Microsoft Windows 10 Personnel 10.00.10586 Compatibilité de Plate-forme : x64 Asus ROG Windows 10 8Go Ram Cubase 7 M-Audio Mobile Pre
A-Dream Last edited by Adreamofficial; 05-16-2016 at 12:19 AM. |
MobilePre reboot (DRIVER_IRQL_NOT_LESS_OR_EQUAL (MAudioMobilPrell.sys) | Adreamofficial | Le Forum en Français | 2 | 06-06-2016 06:03 PM |
Driver_IRQL_Not_Less_or_Equal | cabdriver | Windows | 24 | 03-26-2016 08:40 AM |
Mobilepre USB? | velvetlounger | General Discussion | 5 | 12-13-2012 06:45 PM |
DRIVER_IRQL_NOT_LESS_OR_EQUAL, then- BSOD | TOMsubG | Pro Tools SE and Essential (Win) | 0 | 11-28-2011 04:57 PM |
driver_irql_not_less_or_equal / BSOD when shutting down | zygzag420 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-24-2007 11:54 AM |
