Reading decibel levels in a waveform
I'm just beginning to try to learn Pro Tools, and one thing I can't figure out -- even after searching through the user's manual and the Pro Tools Visual Quickstart Guide -- is how to read the decibel level of a given sound.
I'm trying to compress the dynamic range of a simple voice track. I've been told to set the threshold to three to six decibels below the highest peak in the track. But I can't figure out what the decibel level is of the highest peak in the track. I'm sure this must be ridiculously easy to do, but I can't figure it out. Little help? Thanks. |
Re: Reading decibel levels in a waveform
I say that your ears are the final assessor. You cant have a numbers setting and just enter them. Fair enough people will through experience be able to put in values thatw will be their favourites, but ears and listening must be the final judge.
When numbers and stats in an audio chain become all thats needed, then sound engineers and dubbing mixers have effectively become accountants. Peter |
I did figure out one way to do it, and that's by using the Gain plugin in AudioSuite. You select any part of a waveform and the Gain plugin will give you the decibel reading of the peak in that selection. |
Cmd+click the volume indicator to switch it from volume (level) to peak (in dB).
-kirk |
You're right on about using the gain plug-in for a forensic peak read. I'll read the whole track (not a section) to check for overs and such. Just avoid the temptation to manually 'normalize' every track. 24bit is quiet enough to record at -6 or -12. PT's mix bus will like you for it.
Learn to listen. Listen to learn. |
Oh shoot. I missed your original point.
Chris(binary) said it all (and well) with regards to compression. MR
Never mind -- I think I found it. Is it the Compressor plug-in in AudioSuite? That has adjustments for threshold, ratio, etc.
Input/Waveform Levels | shamrock7171 | Pro Tools 10 | 6 | 06-14-2013 02:28 AM |
Same audio and levels different waveform overview sizes? | talco | Pro Tools TDM Systems (Mac) | 4 | 06-18-2010 09:58 PM |
Decibel Levels | qbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-16-2008 03:13 PM |
Decibel short-course on levels | Park Seward | General Discussion | 0 | 05-06-2003 08:30 PM |
DAT player not reading the master out levels | Sounder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-21-2001 03:42 AM |
