Re: PT 8 useless until fixed
Ok so now It's a lot more effective. Menu / View / Waveform / Power.
We'll see when working on a session for real. Activity monitor still screamed at around 70%. Should be fixed.. |
lesson learned... the rule should be if the problem is user error, i.e. upgrading to an OS version not supported, you should have to apologize for making ridiculous comments like, "PT8 is useless..." I would assume you have plugins that are not Leopard/PT8 compatible as well...
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9 |
I asked them (toontrack) if there was any chance to get this fixed quickly...no answer, no news, just..... "under investigation" And, by the way....the toontrack forum is a joke! You can't even post a thread about any issue...you can just post about beats and sounds... Thanx for communication toontrack... Except that, pt8 LE seems great! Nice new features, UI, and much much better cpu usage..digidesign seems now more generous than ever. Maybe will pt 9 LE bring us complete music production toolkit and/or DV Toolkit for free?? |
so pro tools 8 is not compatible with osx 10.5.6?
[bleep][bleep][bleep][bleep]. i just bought a mac specifically for pro tools use. ive not got pro tools 8 yet but i will soon. do i need to 'downgrade'? ive never had a mac before so am totally baffled by a lot of it and this could just make me cry. someone please clear up for me what i might need to do before loading pro tools. help! |
#16
easy easy easy, please don't cry! You made the right choice, you'll be happy with the mac purchase I assure you. While OSX10.5.6 isn't "officially" supported, many people are running PT8 without any issues on 10.5.6. While it is advised not to upgrade to 10.5.6, you should have success if you have no choice as in your case. You would have the option of calling Apple and having them send you a new set of system disks with 10.5.5 if you really needed to, they should do it for free since it is a new machine. But that could take 5 or 6 days to get depending on where you are.
So I suggest downloading the OSX 10.5.6 combo updater from Apple's site. Just Google "OSX 10.5.6 Combo Updater" and install it. Since you are new to macs, always use the Combo Updater to update to a Digi Supported OS and not OSX's built in Software updater. In fact disable that feature. After running the updater, throw your PT8 disk in and install away. You must then make sure that all your plugins are PT8 and Leopard compatible. When in doubt, just download the newest versions from Digi's site. So go ahead! Load away! FI you have major problems then call Apple and have them send you OSX 10.5.5 system discs.
#17
thanks for the swift reply. what exactly does the combo updater do that the built in updater doesnt?
and thank you for your reassurance. |
#18
unfortunately I'm not a software engineer, and if Digi chimes in they might have better insight, but if Digi says to do it, I tend not to ask questions. The download itself is usually bigger than the file that you get when using the built in Software Updater, so it obviously has extra data that gets installed. I had a friend call the other day that was unable to work after updating to 10.5.6. I told him to try the updater and he is back in business. Not saying this will help everyone but it helped him.
#19
I'm nearly positive you will have good luck if you install the updater and install PT.
#20
well, i am currently getting the updater as we speak. pro tools is still a few weeks off yet from me buying it but its good to have everything ready. so again, thank you very much.
MPT now useless in PT8? | Taliq | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-05-2008 03:45 AM |
Mbox is useless in OSX | spookster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-06-2005 09:39 AM |
T-racks EQ useless | Joz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 01-22-2004 08:25 AM |
Useless Track Pad | bslack | ProControl, Control|24, Command|8 | 0 | 02-21-2002 02:16 AM |
MasterList Useless? | Lee Blaske | Pro Tools TDM Systems (Mac) | 7 | 02-26-2001 07:07 AM |
