Old 05-14-2016, 09:19 AM
orc orc is offline
Default Native Plug-in on TDM System
Hello,
When I send a key signal to a Native Dyn3 Compressor plug-in, I can clearly hear the latency while the listen button is on. But I don't see any latency value in the delay indicator as it shows the delay zero. When I switch the plug into TDM, it works as it should be. But I really wonder if there is a solution in terms of natives. It seems, Delay Compensation does not work for Native Plugins? Do I miss something or this is just how the HD systems work?
I use Pro Tools HD 10 with an Accel 2 on Mac. ADC is on, the long delay is selected.
Old 05-15-2016, 10:03 AM
Barry Johns Barry Johns is offline
Default Re: Native Plug-in on TDM System
I use native plug-ins all the time when mixing. ProTools does delay compensation for native plug-ins as well as TDM plug-ins. Latency and delay compensation are two very different things.
If you're using a combination of our task plug-ins and TDM plug-ins on the same track, you always want to use your Artest plug-ins first, then followed by TDM plug-ins.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 05-16-2016, 03:12 AM
JFreak's Avatar
JFreak JFreak is online now
Try placing a TDM plugin (trim, for example) before that native plugin
Janne
Which AAX Plug-ins come BUNDLED with the purchase of a new HD NATIVE OMNI System relish Pro Tools 11 5 12-28-2013 08:49 AM
Tracking with AAX-DSP or with Native (RTAS or AAX-Native) Plug-ins Oblivion777 Pro Tools HDX & HD Native Systems (Mac) 10 05-18-2012 03:54 PM
Gone from HD system to Native : Best replacement for "pitch' plug-in? simon hunt Pro Tools HDX & HD Native Systems (Mac) 15 03-25-2012 06:28 PM
Install TDM plug-ins on native system georgelegeriii Pro Tools TDM Systems (Mac) 3 08-02-2008 03:38 AM
Native system over TDM WOW! zboy2854 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 11-03-2003 05:18 PM
