Midi controller stopped working with PT 11?
I have a M Audio Keystation 49es. It has always worked with previous versions of PT. But it seems to have stopped working with the most recent version of PT 11. I've read a lot of threads with people having similar problems with their m audio keyboards and PT11. I don't want to buy another one assuming it is broken if that one will meet the same fate. So what are some affordable options for a midi keyboard that will be for sure compatible with PT!!?
specs below.
my specs: iMac 2020 3.8Ghz 8-core Intel core i7 processor Catalina OS ProTools 2020.12 Scarlett Focusrite + Saving to External Harddrive http://MayMcDonoughMusic.com |
Re: Midi controller stopped working with PT 11?
Going by past recent threads it looks like you're still having problems with your keyboard. First thing I would do is to get a free MIDI monitor program like MIDI-OX and use that to see that if at least your keyboard is communicating with your computer. Also make sure that, if you're using USB to connect the keyboard, the keyboard is plugged into a working USB port. Windows turns off USB ports by default as part of their power saving regime. Go into Windows Control Panel and turn off any power saving measures.
Before anyone can make a recommendation as to what to buy tell us this - what exactly do you need the keyboard to do? Just to play in notes or also have controls that PT can read? As long as a keyboard is class-compliant (which essentially means it doesn't need special drivers) or has specific drivers for it, then PT should see it providing you have things set up correctly on your computer. |
Hi! Thanks for responding! I used Midi OX to test the input of the device and it shows that the device is working just fine. I suppose that would mean the usb is also working.
I use the keyboard to trigger notes in protools. So I really jsut need the keys to work as midi triggers. Meaning when I open up a plugin like "Structure" and hit record, I should be able to play piano or drum beats or whatever by pressing the keys on the keyboard. Does that help?
And, after you've turned off USB Power Management, make sure you've done all of the other Windows Optimizations recommended by Avid.
Also, make sure you plug the keyboard into the same USB port every time. If not, and there are drivers, you may need to reinstall them.
Oh also, I tried resetting the midi info in "peripherals". I went to the midi controller tab and chose
#1 Midi Controller: Type: M-Audio 49es Keyboard Receive From: M-Audio 49es Keyboard Send To: none (my keybaord is not listed as an option here...) # Channels: 8 (also no other options) Anyone think I should try something else?
003R MIDI stopped working | oakenhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-09-2015 03:45 PM |
Midi stopped working after Osx 10.8.3 update | Fiachra | macOS | 4 | 03-26-2013 05:42 AM |
Midi Clock stopped working | tonedef | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-15-2009 08:18 AM |
MIDI playback stopped working | Ken Burk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-22-2009 06:52 AM |
Midi Stopped Working: help plz | gary kleiger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-28-2005 02:56 AM |
