Old 07-18-2015, 07:14 PM
Question Re: AAF import error in PT 11.3.1
Originally Posted by dj_tms View Post
I'm just wondering if you guys at AVID have downloaded the AAF and manage to find out anything about the problem. Thanks
I don't know if anyone on Avid's payroll has downloaded it yet. It's past 10 PM local time here and I am not going to try this tonight, as I am too sleepy to give it the proper attention.
Have you tried importing this AAF with Pro Tools v11.2.1?
Old 08-10-2015, 04:38 PM
theresbuzz theresbuzz is offline
Default Re: AAF import error in PT 11.3.1
Bump,
got the same error message. Any solutions to this problem?
Old 01-06-2017, 10:28 PM
Zirus Zirus is offline
Bump
Pro Tools 11.3.1
iMac 27" Late 2012
OSX El Captain 10.11.6
3.4ghz Intel Core i7
20 GB 1600 MHz DDR3
NI Komplete Audio 6
Old 02-25-2017, 03:28 PM
hscully hscully is offline
I am exporting an AAF from Davinci Resolve and I am having the same problem with the same error message. Protools 11.3.1, Win 7 64 bit
any help on this?
Old 02-25-2017, 05:00 PM
Just to be clear, I exported an AAF from Davinci Resolve 12. I went to open session in protools 11.3.1 on a Win 7 64 bit machine, and when I tried to open the AAF I got the following error message:
Could not complete the Open Session... command because an unexpected error happened while trying to find a media file's location
I noticed that there was a fix in 11.3.2 but I am not eligible for that because I do not have HD. What can I do to get this working. I'm pretty stuck here now
  #16
Old 02-26-2017, 09:05 AM
The Weed's Avatar
The Weed The Weed is offline
IIRC, you don't have to be on HD, just on a support plan.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #17
Old 02-26-2017, 09:25 AM
Thanks... I have not purchased a support plan. I'll look into that
  #18
Old 02-28-2017, 06:35 PM
I renewed, got the upgrade and was able to import the AAF after that.
  #19
Old 03-25-2017, 12:45 PM
garnoil garnoil is offline
I am also having an 'unexpected error can not find media folder' when trying to open an AAF with my Pro-Tools HDX . I am in PT 11.3.1. If I upgrade to PT 11.3.2 will this fix this error? Many AAF that I work with import perfectly, but a few do not. I am not sure what software is used to create the AAF that do not work, may be Premier? and I don't know if the creators are doing anything wrong in their AAFs or may be putting video or something else that may be causing the AAF not to work.
In the 'issues fixed' for PT 11.3.2 it list this as a 'fixed issue':
AAF from Premier Pro won't import into Pro Tools. (PT-204486)
I just want to make sure that this will in fact fix the problem that I am having before I upgrade.
Thanks
OMF Import Error.. Need help! Kaotic macOS 2 08-13-2013 07:49 PM
AAF Import Error bradperry macOS 0 04-15-2011 06:10 AM
AAF Import Error on PT LE 7.4.2 kentgibson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-02-2010 05:34 PM
OMF Import error Assertion Error 4044 DUCHUNTER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-08-2005 12:45 AM
OMF Import Error ksrmedia Pro Tools TDM Systems (Mac) 1 12-02-2004 02:38 PM
