#21
Re: $900 for a unit that worked for a week?
Well, unfortunate first post for me. Just received my Eleven two days ago, worked for a short time, then no sound. Reset memory worked for a bit, then no sound. Then found out about the clock issue and bad batch - Then, read a bit here and checked my box and horror of horrors it is a dreaded Rev. E
Have a call into avid, should be getting a follow up call back from them shortly, I hope they will make it right and cross ship one from the "good" stock. The dealer would step up, but they are in N.Y. and I'm in WA State, took a week in route to get the first one, plus don't want to be out of $800 for what would amount to be a month by the time I returned, re ship time etc... on a defectively manufactured product. Also bought the expansion pack so there's another $100. P.S. - I absolutely love the sounds and the tone, gave up on a POD HD500, this one is it, but I just need "it" to work. |
#22
I just received my eleven rack from Amazon and the first thing I did was look on the box and sure enough, Rev E...are all the ER in this revision bad? I haven't even taken it out of the box yet...I'm debating just sending it right back to Amazon.
#23
I have Rev. D and have no problems.
#24
Even on hardware revisions that exhibit the clocking issue, only a few percent of units appear to have any problems. It's very likely that your rev E. unit will function without any trouble. The most common symptom is no audio, usually at 44.1kHz, although sometimes at 48kHz. Switchting back and forth between sample rates usually brings back the audio.
Chris Townsend Guitar Products Architect Digidesign, A Division of Avid, Inc. |
#25
Thanks for chiming in, Chris, I'll give it a try.
Mark |
#26
Could someone clarify if this lack of audio is only when interfacing with ProTools, or is it in stand-alone mode too?
My Sweetwater rep tried to get me a Rev H1 unit...actually, that may already be the one sitting at home waiting for me, I haven't been home in over a week to confirm. |
#27
Mine worked for 2 days then stopped. I had no sound in pro tools and no sound in stand alone mode either.
5 out of 4 people have a problem with fractions... |
#28
Are you sure the "H1" revision Avid is talking about is indicated by the Rev E on the SN sticker and not the actual SN?
I have a brand new Eleven Rack here that says Rev E, but the SN ends in H and it isn't exhibiting any problems. I know a lot of the previous defective ones I saw had a SN that ended in G or G1. If seems strange that Avid would skip from Rev E to Rev H. Can someone from Avid confirm how to tell if this is a rev. H1? Is it by SN or the Rev letter on the SN tag Thanks |
#29
Distribution bottlenecks?
I haven't encountered any problems with my unit, and I've basically left it on since February 2010 when I bought it from MF. The S/N sticker does not contain any "Rev-x" on it but the S/N ends in 11F. Does this mean Rev F? I find it strange that folks buying 11-racks a year later are still receiving Rev-E production runs.
#30
The Eleven Rack hardware revision is designated by the last one or two characters of the serial number. So Moonshine, you are correct that you have a Rev F unit.
PT 10 & my 002 worked last night but not now | Trainwreckmusic | macOS | 28 | 11-28-2012 01:51 PM |
How would this have ever worked? | JrBobDobbs | Post - Surround - Video | 2 | 08-16-2011 09:51 PM |
It worked when it shouldn't have... | paulrgmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-29-2009 12:12 PM |
Troubleshooting worked! | Harpo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-17-2009 07:16 AM |
This has never worked for me.... | Guit4Brains | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-19-2004 05:05 PM |
