Old 02-24-2014, 10:42 AM
mike2205 mike2205 is offline
Default Pro Tools freezing when opening a session
I've been away on tour for 3 weeks so my Mac hasn't been turned on at all. Worked perfectly fine before I left.
Come home to continue work for clients and Pro tools just keeps hanging/freezing whenever I try to open a session. This also happens if I create a blank session or open a session with no active plugs.
I thought I'd solved it when I was told it was a problem with plugins. To put them into the unused folder, restart, open the session, save with plugs inactive then go through as it's supposedly a problem with waves multi-mono/single channel plugs. This worked once, I was able to open the session and work in it fine, but once I'd shut my computer down the problem returned.
I had PT 8.0.1. I've tried updating to 8.0.5, same problem. I've completely reinstalled PT to 8.0.1. Still freezing. If I leave it for 30 mins the session will open but obviously I can't work like this forever. I've got a lot of clients upcoming in the next few weeks and I have current work outstanding.
Mac 10.6.8
PT LE 8
Mbox 2 & Digi 003+ (Dependant on location)
No new plugins were installed to explain the change
Any help would be greatly appreciated.
Cheers
Mike
PT 11.02 freezing after closing a session and opening new session asaffulks Pro Tools HDX & HD Native Systems (Win) 2 12-17-2013 02:49 PM
Session keeps freezing on opening when it is "Restoring Audio Engine Settings" bradykrzemien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-18-2009 10:18 AM
Pro tools le 7 freezing mid session jammfactory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-16-2007 02:22 PM
PT keeps FREEZING when opening session! Help! jephreee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-28-2007 09:27 PM
Pro Tools freezing up mid-session jlee462 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-02-2000 06:55 AM
