Region duplication to bars:beats grid
Is there any easy way to duplicate a region of audio so
it will stay on the bar grid for a whole song without drifting off? I am having great difficulty achieving this. |
Re: Region duplication to bars:beats grid
Hi.
From the Reference Guide, page 296. Duplicating Audio When using Duplicate or Repeat for audio that must fall cleanly on the beat (for loops), it is important that you select the audio material with the Selector, or by typing in the start and end points in the Event Edit area. If you select an audio region with the Grabber (or by double-clicking it with the Selector), the material may drift by several ticks because of sample-rounding.
Tried that - still off grid after about 20 apple-d's at 117bpm..
Are you using the selector tool in grid mode? What happens if you select audio material with the selector tool (grid mode), choose Edit > Repeat, and say 20? Still off grid?
same result - it seems to be gradually getting later
Try "ALT+R" instead.
Still, sounds like your region is not entirely the length of a multiple of one bar. Or do you have a tempo change? Hope it helps! Tim |
Tried that and a lot more...
Can't seem to find the thread Is it possible or a protools limitation? |
Here's one...
http://duc.digidesign.com/showflat.p...=761115&Forum=,f16,&Words=%2Bduplicate%20%2Bexactly%20%2Bgrid&Se archpage=0&Limit=25&Main=761115&Search=true&where= bodysub&Name=&daterange=0&newerval=&newertype=&old erval=&oldertype=&bodyprev=#Post761115 R. |
thanks
so it's all about quantize region then |
Bars and Beats | GTTTT | Pro Tools 10 | 4 | 04-05-2013 04:51 AM |
Grid in bars/beats, display in minutes! am i going mad? | crizdee | macOS | 3 | 03-03-2013 07:06 PM |
Is it possible to zero out Bars and Beats? | jordan23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-23-2004 09:55 AM |
bars and beats.....its off | Mikchek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-03-2003 01:47 PM |
Can I get a bars & beats edit grid from a live cowbell 'click track' ?' | Jules | Tips & Tricks | 10 | 01-15-2000 12:30 AM |
