Old 08-08-2006, 09:26 PM
Hot Voice Hot Voice is offline
Default Can\'t select region to edit
Don't know what I did wrong, but when trying to select a region to trim or delete, there are two "bookends" in the timeline of a ProTools session that will not allow me to highlight the entire region. They're little icons that appear and seem to override placement of the cursor. It's very frustrating, since it makes editing twice as time consuming! Any one else every experience this? Would love some help!
iMac G4 800 MHz
M Box
PTLE 7.4
Firewire Audio Drive
Neumann U87
Old 08-08-2006, 09:36 PM
Shawn Simpson Shawn Simpson is offline
Default Re: Can\'t select region to edit
those little bookends are called the "edit insertion cursors" and you're seeing those in addition to the arrows that are called the "timeline insertion cursors" because you have apparently unlinked them. There is a small icon in the black bar below the tools that has a picture of the bookends and a little set of arrows. That's the "link edit/timeline selection" button. Make sure it's enabled and you should be back in business.
By the way, the shortcut to turn that on and off from the keyboard is shift+/, so if you'll look at the shift key on the right side of your keyboard, you'll probably see a great opportunity to accidentally toggle yourself into a very miserable state.
Old 08-09-2006, 12:08 PM
Shawn,
Thank You! It seems like such an obvious fix, but it's really quite a time-saver. Appreciate your quick response!
iMac G4 800 MHz
M Box
PTLE 7.4
Neumann U87
Select in Region bin won't select region in edit window? innerbooty Pro Tools TDM Systems (Mac) 3 03-24-2013 11:04 AM
Projectmix/Pro Tools/Select a region. yamahadrums macOS 0 03-02-2012 01:45 PM
Can't select a region with fades... austinere macOS 2 08-17-2011 04:01 PM
How do I select every other region in PT8? Possible? Rhythmproject 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-01-2010 12:40 PM
select region (take) with mouse shortcut johnbhoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-10-2010 07:44 AM
