Protools 9.0.6 'static on playback' & no PT Headphone playback
Hi folks,
Any advice very much appreciated re the following 2 issues please :) The computer has been custom built with Protools 9 recommendations taken into consideration in its construction. Although I basically handed the company (who put it together) all the AVID links and hints and recommendations and then just added what size machine I wanted, so I am sincerely hoping all specifications required for PT are as it should be. I then installed PT 9 on the computer and upgraded it to PT 9.0.6 I have a PC Windows 7. I have done the Optimisation recommendations. I have a Focusrise Saffire PRO 40 interface. I have the latest drivers for that. It is Firewire connected to the computer. My problem is: When I playback a recorded track or the 'Protools Demo Track' there is a 'static' sound randomly through the track. By 'randomly' I mean I could play the track several times and it would be in different spots. If I bounce the track down to mp3 then play the track back through the same computer there is still random static on the playback via the computer.... However if I play the track on a separate computer there is no static on the playback from the bounced down mp3 track. That's one issue: Number 2 issue: With playback from the Protools, I can use the Focusrite Saffire Pro 40 interface to get audio to playback from PT to my monitor speakers. So that is with the PT engine setting on Saffire, but I don't get any headphone send for monitoring from the computer via PT. If I change the PT engine settings to the computer sound card, (and I recently downloaded a generic one ASIO4ALL v2 to get PT to open at all on the computer when not connected via the interface engine) ....although I can play a cd eg., in the computer I am using and hear it in the headphones..... I can't hear playback from PT if it is playing a song in the headphone send on the computer. What would be the issue there? Other things I have done: I have Screen prints of all the PT settings.....if anyone would like to see them, re the possibility of a setting not being correct. I maybe able to post them here I don't know. Otherwise, I have done some recording with PT and I love it!!!!!!!!! ....but the above issues mean something must be awry somewhere.... if anyone can throw some light on what could be the problem/s that would be absolutely fantastic!!!!!! :))) I have added a 'Sandra' report of the computer below. Many thanks VC -------------- Computer Overview. Model : MSI MS-7757 Serial Number : To be fille*********** Chassis : MSI Desktop Mainboard : MSI Z77A-GD80 (MS-7757) Serial Number : To be fille*********** BIOS : AMI (OEM) V1.4 12/17/2012 Intel vPro : 8.00.10.1464 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (4C 8T 4.2GHz, 4.2GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1155 Chipset Memory Controller : MSI Core (Ivy Bridge) DRAM Controller 100MHz, 2x 16GB DIMM DDR3 1.6GHz 128-bit Memory Module(s) Memory Module : A-Data DDR3 1600G 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : A-Data DDR3 1600G 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : A-Data DDR3 1600G 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : A-Data DDR3 1600G 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : BNQ BenQ G2450H (1920x1080, 24.0") Video Adapter : 2x NVIDIA GeForce GTX 660 Ti (7CU 1344SP SM5.0 1GHz/1.23GHz, 384kB L2, 2GB 6GHz 192-bit, PCIe 3.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GTX 660 Ti (1344SP 7C 1GHz/1.23GHz, 384kB L2, 2GB 6GHz 192-bit) OpenCL GP Processor : NVIDIA GeForce GTX 660 Ti (1344SP 7C 1GHz/1.23GHz, 384kB L2, 2GB 6GHz 192-bit) Compute Shader Processor : 2x NVIDIA GeForce GTX 660 Ti (1344SP 1GHz/1.23GHz, 384kB L2, 2GB 6GHz 192-bit) CUDA GP Processor : NVIDIA GeForce GTX 660 Ti (1344SP 7C 1GHz/1.23GHz, 384kB L2, 2GB 6GHz 192-bit) CUDA GP Processor : NVIDIA GeForce GTX 660 Ti (1344SP 7C 1GHz/1.23GHz, 384kB L2, 2GB 6GHz 192-bit) Storage Devices KINGSTON SV300S37A120G (120GB, SATA600, SSD) : 112GB (C:) Hitachi HDS721010DLE630 (1TB, SATA600, 3.5", 7200rpm, 23MB Cache) : 932GB (D:) Hitachi HDS721010DLE630 (1TB, SATA600, 3.5", 7200rpm, 23MB Cache) : 932GB (E:) Generic USB SD Reader (USB2) : N/A (H:) Generic USB CF Reader (USB2) : N/A (I:) Generic USB xD/SM Reader (USB2) : N/A (J:) Generic USB MS Reader (USB2) : N/A (K:) HL-DT-STDVDRAM GH24NS90 (SATA, DVD+-RW, CD-RW) : N/A (F:) HL-DT-STDVDRAM GH24NS90 (SATA, DVD+-RW, CD-RW) : N/A (G:) Logical Storage Devices OS_Install (C:) : 102GB (NTFS) @ KINGSTON SV300S37A120G (120GB, SATA600, SSD) Data (D:) : 932GB (NTFS) @ Hitachi HDS721010DLE630 (1TB, SATA600, 3.5", 7200rpm, 23MB Cache) Data (E:) : 932GB (NTFS) @ Hitachi HDS721010DLE630 (1TB, SATA600, 3.5", 7200rpm, 23MB Cache) Removable Drive (H:) : N/A @ Generic USB SD Reader (USB2) Removable Drive (I:) : N/A @ Generic USB CF Reader (USB2) Removable Drive (J:) : N/A @ Generic USB xD/SM Reader (USB2) Removable Drive (K:) : N/A @ Generic USB MS Reader (USB2) Optical Drive (F:) : N/A @ HL-DT-STDVDRAM GH24NS90 (SATA, DVD+-RW, CD-RW) Optical Drive (G:) : N/A @ HL-DT-STDVDRAM GH24NS90 (SATA, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : MSI Panther Point LPC Controller LPC Legacy Controller 1 : T0 10-05 Audio Device : MSI Panther Point High Definition Audio Controller Audio Device : MSI GK104 HDMI Audio Controller Audio Codec : nVidia GeForce 6800 Ultra [NV40.0] Disk Controller : MSI Panther Point 6 port SATA AHCI Controller Disk Controller : MSI Asmedia 106x SATA Controller USB Controller 1 : MSI Panther Point USB xHCI Host Controller USB Controller 2 : MSI Panther Point USB Enhanced Host Controller #2 USB Controller 3 : MSI Panther Point USB Enhanced Host Controller #1 FireWire/1394 Controller 1 : 22785 FW643 PCI Express1394b Controller (PHY/Link) SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Network Services Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet) Wireless Adapter : Atheros AR9287 Wireless Network Adapter #2 Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 7.8 |
Re: Protools 9.0.6 'static on playback' & no PT Headphone playback
http://us.focusrite.com/contact-support Quote:
Best Regards. Katherine Kaplan // Focusrite Technical Support http://www.focusrite.com/answerbase/en/ |
Playback Problem: Overpowering Static Noise: Pro Tools can not get playback fast enou | JLue | Pro Tools 9 | 1 | 08-04-2011 08:59 AM |
Fuzzy Static with ProTools playback and window media files playback | 39lashesmedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-25-2011 05:41 PM |
Static "Playback" with Protools and Static "Playback" with windows files | 39lashesmedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-20-2011 05:57 AM |
Protools and eleven rack - CONSTANT static during playback | leftyjay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-28-2010 06:26 AM |
Static on Playback (Protools 6.0, Mbox | boatsinbottles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-18-2004 11:50 AM |
