Old 03-16-2009, 03:44 PM
Bobby P Bobby P is offline
Default Digi Suite Plugs come up blank?
Hi. I'm running PT 6.01 on a G4 Mac (yes its an older system). Recently, the AUDIOSUITE plugins are not working. When I try to run...say the time compressor/expander over a region, when I load up the plugin, the window comes up empty. The TDM plugins are working fine, just the ones in the audio suite menu do not work (or are even viewable) any more. This system has run flawlessly for many years and this problem has just started. Your help is GREATLY appreciated. Thanks. Bob
Last edited by Bobby P; 03-16-2009 at 05:57 PM. Reason: mis typed AUDIO SUITE...not Digisuite
Old 03-16-2009, 05:58 PM
Default Re: Digi Suite Plugs come up blank?
Sorry..I should have said "Audio Suite" plugins.
Old 03-16-2009, 08:53 PM
Tried trashing the prefs and associated files and folders. Dumped the Database folder on the external drive, etc etc. When I re-launched a session, the Audio Suite plugin would display (FINALLY) but if I closed it and re-opened it or a different one...back to the same...blank box. Sometimes you could see only a few buttons on the interface but mostly blank and definately not responding at all to clicks. I'm not happy.
Old 03-17-2009, 02:12 AM
crizdee's Avatar
crizdee crizdee is online now
Uninstall pro tools!
trash all prefs and data base folders
repair permissions!
reboot the mac!
re-install Pro Tools
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-18-2009, 05:31 PM
Thank You. I was hoping that there might be a solution that did not include un-install. But if that is necessary, the prudent thing to do is now upgrade the software version. I think I can get to 6.9 for cheap money. Hopefully I will still be able to use my Waves Gold Bundle. I'd hate to have to purchase new plugs.
Thanks
Bob
Blank file after Audio Suite render? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-08-2012 08:58 AM
AIR plugs have no Audio Suite versions daeron80 Pro Tools 9 6 01-26-2011 01:17 PM
Why are some plugs in Audio Suite but not Sam C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-01-2009 05:05 PM
Crash when using Audio Suite Plugs MDH25 Pro Tools TDM Systems (Mac) 8 10-06-2001 04:52 AM
Audio suite plugs mono only? dkrausz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-16-2001 07:09 AM
