Old 06-19-2009, 02:38 PM
admix's Avatar
admix admix is offline
Default File association issue when starting session from template
When I begin a new PT session from a PT8 template file, using the N command, the .ptf file created doesn't get associated with Pro Tool, but strangely with Sound Miner.
This doesn't affect the session while I'm running, but is a minor inconvenience when I need to re-open it later.
I can ctrl-click the session in question and tell it to "always open with" PT, and that cures each individual session, but every new session created this way yields the same results.
Sessions created the "old way," with a user made template file saved as a stationary pad do not exhibit this behavior.
Thoughts?
Thanks,
-Steve
PT8 cs3
OSX 10.5.5
8 Core 3.2G Xeon
6GB RAM
Stephen Rosen
SonicUnion
19 Union Square West
New York, NY 10003
Old 06-21-2009, 08:00 PM
RecRoom RecRoom is offline
Default Re: File association issue when starting session from template
Hi Steve!
Looks like you've stumped everyone. Are you saying that when you double click the new session it opens up soundminer and not ProTools?
Does it do this when you take a template created the "old way" and refer to it as a template within ProTools? If not, sounds like it might be a finder issue as opposed to a ProTools issue.
Maybe try this FileType program? Did you try this way as well?
Hope all is well!
Jeff Hinton
Editor/Mixer
http://www.jeffhinton.tv
Old 06-21-2009, 08:20 PM
To be clear... changing the file type of the .ptt file... not the session file.
Jeff Hinton
Editor/Mixer
Old 06-21-2009, 09:12 PM
docbop docbop is offline
Do a "Get Info" on the file and one of the setting is "Open With" there you can set the app' to open that file extension with.
Steve B.
If you think you can or if you think you can't, you're right.
Old 06-22-2009, 08:18 AM
admix's Avatar
Originally Posted by RecRoom View Post
Hi Steve!
This is the one that worked.
Hope all is well!
Thanks Jeff!
Sometimes it's the stupidest things. I know this stuff. Must re-engage brain. Getting older sucks.
-Steve
Stephen Rosen
SonicUnion
New York, NY 10003
Old 06-23-2009, 06:54 AM
No worries. Best of luck!
Jeff Hinton
Editor/Mixer
HTML code is On
Quicktime file starting over in session krieram Post - Surround - Video 4 12-17-2016 03:59 PM
File numbering in template session Carsonic macOS 2 12-01-2012 07:13 AM
File association cpnraisnuts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-20-2005 11:41 AM
Session Template/ Sample Rate Issue Iain Graham Pro Tools TDM Systems (Mac) 7 12-20-2004 03:56 PM
session template issue... gitarzan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-12-2003 11:29 AM
