  #21
Old 07-19-2019, 03:47 PM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Mac Pro 5.1 Mojave - what GPU cards work?
Thought I would give a quick update
So I have not yet updated to Mojave.
But I have updated my Graphics card. On my Mid 2010 Mac Pro (as per sig line below)
I got the:
Sapphire 11265-05-20G Radeon Pulse RX 580 8GB GDDR5 Dual HDMI/ DVI-D/ Dual DP OC with Backplate https://www.amazon.com/Sapphire-1126.../dp/B06ZZ6FMF8
COMeap Dual Mini 6 Pin to 8 Pin PCI Express Video Card Power Adapter Cable for Mac Pro Tower/Power Mac G5 15-inch(38cm) https://www.amazon.com/COMeap-Expres...s%2C546&sr=1-4
And for my older Apple Cinema Display (with mini plug)
I got the Cable Matters DisplayPort to Mini DisplayPort Adapter (DP to Mini DP)
https://www.amazon.com/Cable-Matters...0FBPGD3T7JN56J
All toll $207
And I just installed it all which was a breese about 5 to 10 minutes.
The procedure was ---disconnect all power and plugs on back or Mac Pro open up side.
#1 undo the side PCIe slot retainer two finger tight wheels. Pull retainer down and out.
#2 Press the button on the fan housing to slide the fan and Long PCIe retainer bar towards the front
#3 pull out old CPU and the old power supply cabe
#4 push the two new cable 6 pin connectors into the connectors on the mac
#5 push the 8 pin end into the Sapphire
#6 push the Sapphire into the slot
#7 push the fan housing and retainer bar back into position
#8 put the PCIe side slot retainer back on
#9 put the side panel back on the Mac
#10 put the DP to mini Dp cable adaptor on one of the DP ports
#11 plug all the cables back into the back of Mac
Easy peasy
Power on and boot the Mac,,,, black screen for 15- 20 seconds, then slight boot screen flash, and the desktop screen appears
Honestly the no boot screen is a total non issue. Working great so far
Thanks for everyone's help
System :
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4
Enjoy the Journey
.... Kev...
  #22
Old 01-02-2020, 06:30 PM
sicijk sicijk is offline
Hello all and happy new year!
I have a 2009 4,1 to 5,1 Macpro with 10.13.6 which I'm planning to give a bit of life and less obsolescence with dual CPU X5690, more RAM, M2 boot and a GPU.
Coming from PT10 on 10.8.5 with nice experience, exception for 4GB RAM maximum use (16GB installed).
But now I'm experiencing lots of lag on PT 2019(.12)(.10) on even the most simple session. I mean... The visualisation cannot stay behind my mouse moves and this slows me back a lot..
Also navigating the session is quite laggy.
I dont believe it's a CPU thing...
I believe it's a GPU thing.... Am I guessing correctly?
Will I appreciate better performance? Or am I pointing completely wrong?
Thanks for you insight and shared experience
  #23
Old 01-03-2020, 08:33 AM
tclash tclash is offline
I also have a 4,1->5,1 (single X5690) and was experiencing that same lag on High Sierra. Since upgrading GPU and installing Mojave I haven't had any problem.
  #24
Old 01-03-2020, 09:03 AM
Are there any cards out there that are currently available that do Metal AND you get the regular Apple boot screen? That combo seems to be as scarce as hen's teeth. eBay and used cards are a no-go. Also would be nice to find a card that doesn't block the next slot up from the video card. I've read about a number of them that do that and leave one with just two open slots. I use one for my system ssd and would like to put my samples on an ssd in the other slot.
That latter brings up an interesting question and that is: apparently Metal compatible cards generate a lot of heat and I have to wonder how or if that would affect performance, especially of the ssd's.
  #25
Old 01-06-2020, 12:15 PM
Thanks for your answer!
Good to know so!!
Ordered one too.
Do you have the boot screen or not?
PC Windows 10, Ryzen 3900X, 64GB, NVIDIA GeForce GTX1650
//MacPro 4,1(2009) flashed to 5,1-OSX 10.14.6-PT Ultimate 2020.03-64GB RAM-Radeon RX560 2GB
  #26
Old 01-06-2020, 04:32 PM
Good to know so!!
Ordered one too.
I put in a flashed AMD Radeon 7950 3BG and yes I have boot screen. It's occasionally a little quirky (left-open windows sometimes come back in different places when I boot up), but nothing major at all. I'm running two "classic" Apple 20" LCD monitors.
After living with laggy GUI through several OS's and PT updates, it's been working great since I upgraded a year and a half ago.
  #27
Old 01-07-2020, 12:34 AM
Hopefully i'll get good results with the RX560 too.
I'll post the update of what will happen.
thanks
  #28
Old 01-07-2020, 12:59 PM
The golfer The golfer is offline
The msi RX560 works really well with Mojave 10.14.6. We installed two of them in two different Pro-tools rigs without a problem. We also bought a RX580 and realized it is not a viable solution for HDX users, because the 580 needs all the power from the single power cable.
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
  #29
Old 01-07-2020, 01:25 PM
off the wall's Avatar
You can very easily power the HDX card from either the optical bay or one of the SATA bays.
offthewallproductions
  #30
Old 01-08-2020, 11:38 PM
Padje Padje is offline
Thinking of updating gpu to, but in the same boat considering power for videocard in combination with HDX and UAD
Could you elaborate with cable you used ? And where to buy ?
Thanks a heap !
Will the cards in my G5 work in a new Mac Pro? megahurt Pro Tools TDM Systems (Mac) 8 10-09-2009 04:04 AM
Do all MIX Core cards work in G4s? Sensei Pro Tools TDM Systems (Mac) 0 09-10-2004 05:52 PM
D24...will my cards work in a G4? Allbaldo Pro Tools TDM Systems (Mac) 4 10-28-2002 06:48 AM
Do firewire cards work with PT? Allbaldo Pro Tools TDM Systems (Mac) 8 09-09-2002 07:00 PM
PT Cards work in all countries? SteveGarman Pro Tools TDM Systems (Mac) 1 03-10-2001 09:18 AM
