Procontrol/Ethernet Error. Help anyone?
First of all apologies for posting here , rather than the dedicated 'procontrol section', but i thought it more likely that folks would actually notice here.
So, in the middle of a session, up pops the dialog box: "An error occurred while trying to establish Ethernet communication. Please Check all Ethernet connections" ..& my Procontrol (+3 fader packs) go dead. Oh Dear. So, i think i've eliminated the G5's ethernet port from being the problem, as the Computer can still get on the Internet using an ethernet lead. If i take this same ethernet lead & plug it straight into the back of my procontrol main-unit, I get the aforementioned error. I get the same error if i have no ethernet lead at all plugged into the G5. I've done the usual software things (trashed the digi prefs/database, run cocktail), still no joy. Has my procontrol just died? Are there any other software or lead swapping type things to try? Anyone have any other suggestions? thanks in advance as ever:) ru x
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control http://www.lostboysstudio.com |
Re: Procontrol/Ethernet Error. Help anyone?
Hi Ru,
Is there a reset on the pro control? there is on the control 24! You could try re-installing the pro control bundles, i think you would have to run the Pro Tools installer again to install them. or here's an upload of mine, you should be able to just drop these in the controllers folder/pro tools/digidesign/applications... there's 2 pro control bundle and pro control_m bundle... The download page link is: http://www.sendspace.com/pro/arrblm Or else try a complete install of PT. using the safe option will just replace the PT files and not touch any third party stuff or authorizations etc. Chris
I've done a procontrol reset, & tried your procontrol bundle. Still no joy. It seems i'm still on OS 10.4.5 & protools 7.2 (no cs) . Is it worth updating both the OS & Protools as far as they will go revision wise? Am downloading a protools updater currently. It's so odd the way it suddenly stopped working in the middle of a session. Protools doesn't let me select *any* of the separate fader packs, which makes me think its less of a procontrol/fader-pack issue, & more of an ethernet/protools one. Weird that i can still get on the net though, if my ethernet is down?
Yes try re-installing PT or try updating to the latest cs version. either way i would run the uninstaller first, its in the pro tools folder in applications. install 7.2 which is a complete installer, then the latest cs update. If you're going to update the MAC OS, then don't forget to use the combo updater! Do you know anyone with LE on a laptop or another PT user who you could test the pro control with? would tell you where the problem lies! Hope you get it fixed! Chris
[/QUOTE]]Hi, Yes try re-installing PT or try updating to the latest cs version. either way i would run the uninstaller first, its in the pro tools folder in applications. install 7.2 which is a complete installer, then the latest cs update. If you're going to update the MAC OS, then don't forget to use the combo updater! [/QUOTE] ..downloading currently ! [/QUOTE] Do you know anyone with LE on a laptop or another PT user who you could test the pro control with? would tell you where the problem lies! [/QUOTE] Ah, yes i do...he's on the latest version of LE 7.4 on a macbook....will that see the procontrol ?
Well. Updating Both OS & PT fixed it !
How very strange though. That particular combination of 10.4.5, PT 7.2 & Procontrol has been working for me, with minimum fuss for 6 months, probably switched on 16 hours/day, 6 days a week. How weird that it should suddenly die like that in the middle of a session...then how weird that updating the software fixed it... Thanks for the help Chris.....right....back to the music ! x
ProControl and second ethernet card ? | sonicsam | Tips & Tricks | 1 | 07-03-2003 03:03 PM |
Second ethernet card and ProControl ? | sonicsam | Pro Tools TDM Systems (Mac) | 7 | 07-02-2003 06:19 AM |
Second ethernet card and ProControl ? | sonicsam | ProControl, Control|24, Command|8 | 0 | 06-30-2003 05:27 AM |
Procontrol, USB to ethernet Adapter | spigots | ProControl, Control|24, Command|8 | 4 | 02-21-2003 04:49 PM |
Ethernet and ProControl and FileSharing | SaturnSound | ProControl, Control|24, Command|8 | 3 | 07-18-2001 11:36 PM |
