Old 06-27-2014, 01:50 AM
garret garret is offline
Default Video satellite le/intensity shuttle thunderbolt sync drift
Hi
We are using a video satellite le on a Mac mini with intensity shuttle thunderbolt. We are getting sync drift over time. Main system is 10.3.9 on mac pro. Now I know we don't have any video ref etc going in and I assume this is the issue but the intensity has no video ref input and I'd need to get an expansion chassis to put in a sync io. But I see other people have this working without all that so I'm wondering if anyone has any ideas on how to get this to work? Or any helpful tips.
Thanks
Garret.
IMDB
Old 06-27-2014, 02:54 AM
Default Re: Video satellite le/intensity shuttle thunderbolt sync drift
Originally Posted by garret View Post
Hi
Thanks
Garret.
A sync HD and a gen-lockable card a common video ref are the only way to maintain sync over time. No way around that at this point.
There's no way to accurately sync two different machines without locking them to a common clock.
Old 06-27-2014, 05:37 AM
Postman Postman is offline
Can you install SyncIO on the main rig to lock to the satellite's analog video output?
Old 06-27-2014, 06:38 AM
Thanks guys. That's what I thought unfortunately it's literally just a Mac mini with the intensity shuttle out of it going to projector so no way to insert video ref in the chain. I guess we'll need to get some thunderbolt expansion chassis and a deck link sdi or similar that can take ref. Sound feasible?
IMDB
Old 06-28-2014, 05:31 AM
Shuttle's analog video output could be used as master clock, similar to the way kdarbyshirebryant is using an AES/SPDIF output.
Old 06-28-2014, 05:44 AM
Thanks Postman.
Worth a shot but I don't think the Intensity shuttle outputs Hdmi and composite video at the same time. I'll have a look.
IMDB
Old 07-01-2014, 03:41 AM
Kuba Pietrzak Kuba Pietrzak is offline
I can't talk about the Intensity shuttle, but Decklink Extreme HD outputs composite, if you play SD quicktime. If you play HD quicktime, the composite outputs "strange things"...
best,
Kuba
Old 02-27-2015, 10:07 PM
MixerGuy MixerGuy is offline
Hi
Thanks
Garret.
How much drift, over how much time ?
Old 02-28-2015, 11:28 AM
M Baginski M Baginski is offline
Thanks Postman.
It uses all available outputs simultaneously.
HTML code is On
Blackmagic Intensity Shuttle USB3 compatible with protools video? Dolly Post - Surround - Video 3 08-30-2014 08:42 AM
Blackmagic Intensity Shuttle Thunderbolt and PT? Erik Olsson Post - Surround - Video 5 10-05-2012 01:21 PM
Thunderbolt: blackmagic Intensity shuttle OR Extreme? MixerGuy Pro Tools HDX & HD Native Systems (Mac) 6 06-10-2012 12:18 PM
Blackmagic Design Thunderbolt shuttle?...how is it with Pro Tools for video? PT user Post - Surround - Video 0 05-10-2012 02:45 PM
sync video with pro tools using satellite le ericlees Post - Surround - Video 6 03-13-2010 09:36 PM
