Old 03-09-2014, 06:08 PM
lownotesinc lownotesinc is offline
Default Using VEPro5 Server w/ PT10 HD
I set up VEPro5 server today with Pro Tools 10 HD.
Q(s): In 32bit mode, is it independent of PT? In other words will it it function similar to Kontakt 5's memory server? Can I access more of my computer's installed RAM?
I've noticed, (by checking Pro Tool's cpu usage window) that my PT session's cpu percentage is way lower when using VEPro5 server with cpu hungry VI's like Ivory, Chromaphone, etc.
Old 03-10-2014, 04:33 AM
matt_the_manic matt_the_manic is offline
Default Re: Using VEPro5 Server w/ PT10 HD
yes it is independent ...in 32bit you have additional 5GB for more virtual instruments, samplers and samples in your RAM... I do not know about the K5 memory server but the benefits of using VEpro5 together with PT10HD are remarkable. example: try kontakt ni session strings as RTAS or AAX and do the similar while using VEpro and insert it as an AU under macosx or VST under windows. watch the cpu percentage and you will notice the differences. keep in mind you are able to run VEpro5 64bit together with ProTools 10HD (which is 32bit) ...this way you do not have that limit of 5GB anymore... your installed RAM is the limit then... VEpro5 is essential for ProTools HD music production... it should be bundled I would say... the best investment one can do... especially true for PT11...
Old 03-10-2014, 11:55 AM
Thanks Matt! I have a separate 64bit computer on a LAN with my Pro Tools HD rig. It's essential of the big VI intensive sessions. Your reply helped me understand how VEPro5 in server mode can help when run in tandem on my PT machine.
Much appreciated!
-Mark
VEPRO5 not showing up in PT11 massimosammi AAX Plug-ins 3 07-15-2013 05:02 AM
500 Internal Server Error We're sorry but the web server encountered an unexpected c DrumEatDrum Getting Started 10 07-09-2013 11:47 AM
PT10 on a Windows Server Multi CPU setup txshonk Windows 0 01-31-2012 07:16 AM
Mac Mini Server w/ Lion for PT10? De93 macOS 8 11-12-2011 06:51 PM
Files transfered server-server relay still downloaded from remote server Phill Barrett Aspera DigiDelivery 1 03-19-2010 01:58 AM
