You are running out of CPU Power
My Laptop always tells me: "You are running out of CPU Power..."
No matter if I am just listening, recording or bouncing a track. I had this problem with my old laptop too. But now I have 8GB Ram, an i7 processor and I am recording on a 7200 rpm external drive. Why do I get this error again and again?? |
Re: You are running out of CPU Power
I've found in cases where there is no logical reason for getting CPU errors, that a plugin is to sometimes blame. Even if it's not used on a track, just having it load as PT loads can cause it. Have you double and triple checked that all your plugins are current?
Also, have you done any troubleshooting of your own? Have you repaired disk preferences, and deleted the ProTools caches and databases? Even these things can cause it. Without more of a detailed list of what you HAVE tried if anything it's hard to know what to suggest! |
check core parking too
Thank you for your input. Here is a bit more Information about my system:
Windows 8; 64-Bit Pro Tools M-Powered Essentials 8 GB Ram Intel (R) Core (TM) i7 4500U CPU @ 1,80 GHz Size of the session max. 800 MB, but I also got the error message when bouncing a session with only one Instrument on it. Does this help? How can I optimize my system per avid specs? |
A Sandra report would help as well. Read the 'Help us to help you' for what is needed and how to do it. |
Can someone tell me where I can change the language?
I can give you a german overview until now, but I guess that doesn't help much: SiSoftware Sandra Nr Hostname : ****** Arbeitsgruppe : WORKGROUP System Modell : Dell Inspiron 7737 Shark Bay ULT Serialnummer : 4V3**** Gehäuse : Dell Tragbar Mainboard : Dell 019P17 Serialnummer : .4V3R2Z1.CN7************ System BIOS : Dell A05 10/31/2013 Intel vPro : 9.05.14.1724 Gesamtspeicher : 7.9GB DDR3 SO-DIMM Prozessor(en) Prozessor : Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz (2C 4T 3GHz, 3GHz IMC, 2x 256kB L2, 4MB L3) Sockel/Slot : FC PGA947 Chipsatz Speichercontroller : Dell Core (Haswell ULT) DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit, Interne Grafikeinheit Speichermodul(e) Speichermodul : Hynix (Hyundai) HMT451S6AFR8A-PB 4GB DDR3 SO-DIMM PC3-12800S DDR3-1600 (11-11-11-29 5-40-13-6) Grafiksystem Monitor : LGD PnP-Monitor (Standard) (1600x1200, JXWY4€173WD1 , 17.1") Grafikkarte : Intel(R) HD Graphics Family (20CU 160SP SM5.0 600MHz/1.1GHz, 1.8GB DDR3 1.6GHz 128-bit, Interne Grafikeinheit) Grafikprozessor OpenCL GP-Prozessor : Intel(R) HD Graphics Family (160SP 20C 600MHz/1.1GHz, 1.8GB DDR3 1.6GHz 128-bit, Interne Grafikeinheit) Compute Shader Prozessor : Intel(R) HD Graphics Family (160SP 20C 600MHz/1.1GHz, 1.8GB DDR3 1.6GHz 128-bit, Interne Grafikeinheit) Physische Speichergeräte WDC WD10JPVX-75JC3T0 (1TB, SATA600, 5400rpm, 8MB Cache) : 932GB (C:) HL-DT-ST DVD+/-RW GU90N (8.4GB, SATA150, DVD+-RW, CD-RW) : 8GB (D:) Logischer Speichergeräte OS (C:) : 918GB (NTFS) @ WDC WD10JPVX-75JC3T0 (1TB, SATA600, 5400rpm, 8MB Cache) WINRETOOLS : 490MB (NTFS) PBR Image : 13GB (NTFS) Pro Tools M-Powe (D:) : 8GB (CDFS) @ HL-DT-ST DVD+/-RW GU90N (8.4GB, SATA150, DVD+-RW, CD-RW) Peripherie LPC Hub Controller 1 : Dell Lynx Point-LP LPC Controller LPC Legacy Controller 1 : Winbond WPCE775LA Audio Gerät : Dell Lynx Point-LP HD Audio Controller Laufwerkscontroller : Dell Lynx Point-LP SATA Controller 1 [AHCI mode] USB Controller 1 : Dell Lynx Point-LP USB xHCI HC USB Controller 2 : Dell Lynx Point-LP USB EHCI #1 System SMBus Controller 1 : Intel ICH SMBus Drucker- und Faxgeräte Drucker : Microsoft XPS Document Writer v4 (600x600, Farbwiedergabe) Drucker : HP Officejet Pro 8600 Class Driver (600x600, Farbwiedergabe) Fax : Microsoft Shared Fax Driver (200x200) Netzwerkdienste Netzwerkadapter : Realtek PCIe GBE Family Controller (Ethernet) Drahtlosadapter : Intel(R) Dual Band Wireless-N 7260 (802.11n (HT), AES-CCMP, 144Mbps) Energieverwaltung Batterie Nr. 1 : Samsung SDI DELL 62VNH3B 57.72Wh/3.70Ampere pro Stunde Betriebssystem Windowssystem : Microsoft Windows 8 Home 6.02.9200 Kompatibel mit Plattform : x64 Windows Leistungsindex Aktuelles System : 5.8 |
Some systems with integrated graphics have had issues. Yours may be one of them.
And, disable the Wireless while running Pro Tools. The optimizations are here>>> http://avid.force.com/pkb/articles/e...-Optimizations
thank you!
What can I do if mine is one of them? |
You only have one hard drive, and it's only 5400 rpm. BIG problem. You need a dedicated 7200 rpm recording drive. From AVID troubleshooting:
IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive. Pro Tools supports recording and playback to a secondary drive that meets the following requirements:
running out of cpu power??? | amoretam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 10-26-2010 11:58 AM |
Running out of CPU Power Tip Here | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-08-2008 08:43 PM |
Running out of CPU Power | npratt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-20-2004 04:04 PM |
running out of cpu power | Jumpman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-06-2004 06:07 AM |
Running out of CPU power w/ 2.6 ghz 1GB of RAM?!?! | 72reissue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 06-29-2004 04:56 PM |
