#21
Re: which pitch correction software is best?
Also still curious to hear from people familiar with the Waves, Melodyne, and now ReVoice if there is a quick and dirty mode in any of those like "automatic" in Autotune. I'm checking my post-RTAS options! Thanks
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
#22
The problem with a 'push a button and everything is peachy' type of automatic tuning is that it will just be a generic, one-size-fits-all result. And what one person thinks is good, the next will say is awful. Vocals are like any instrument... they should be unique to the muso. The idea with tuning should be more about polishing than fixing. Bad singers will always be bad singers. There will never be a plug-in to fix that. I just finished an albums worth of stuff for a mate that had two very good singers alternating between lead and backing vox. Each one of them required a different approach as their technique was different.. One sang with a bent towards going just a skosh flat, but wavering back to pitch... It suits his voice and the songs he writes very well. All I did was to make sure that when he went flat, he didn't go too flat, or sharp... Knocking the rough edges off so to speak. The other voice was a female and prone to a lot of vibrato and gymnastics which usually suited well, but upon retrospection, was decided just a tad too much in places.. With melodyne I'm able to subtly massage the vibrato/pitch/formant/whatever and make things fit together.. Melodyne kicks serious butt. I have Waves tune, Autotune, etc.. but once I got to Melo.. I have never stopped looking. I use it with Serato P-n-T Pro and Revoice Pro to handle anything that comes up. They just work every time and are good. The best tuned voice is one that doesn't sound like it.. It sounds natural and flawed, but right... somehow just right. And that, is my $.02.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
#23
I never try to mix the tuned a the original "untuned" part. This is the only way you would hear a subtle shift. This could also be resolved easily with Revoice pro or vocalign. Revoice does not have a "Auto" pitch function. Must be done manually though it has some great editing abilities once you get the flow of it. It does have the ability to match pitch though if you had a part that is in tune correctly. Or you could tune 1 track and be able to match the other tracks in both time and or pitch. Very powerful in this area.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#24
#25
$600 puts all ur George washington's in order!!!!
#26
No doubt there, But if you need to buy or upgrade Vocalign, it would make no sense to spring a few more bucks for this with a multitude of capabilities more than Vocalign. Check out its doubling capabilities....KILLER, havent even talked about that yet
#27
With BGV's, you can SORT OF get away with what I call "quick and dirty" Melodyne. Draw a box around the entire part(on the Melodyne screen) and double-click to snap everything to the note grid. And, since its BGV's, you can use the vibrato adjust tool to remove some vibrato and you're done(maybe).
#28
#29
#30
For mono tracks Waves Tune... for polyphonic pitch correction (piano, gtr, BGV's) Melodyne Editor... Melodyne can also save the day fixing mistakes on stereo orchestral tracks... esp. if the material is not too complex.
Pitch Correction Software Recommendations? | DingyDJ | Pro Tools 10 | 13 | 04-01-2013 09:36 AM |
pitch correction software | Bender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 07-25-2009 06:22 PM |
Which Pitch Correction is Best ? | wolfman_rob | Pro Tools TDM Systems (Mac) | 22 | 01-29-2008 04:15 AM |
pitch correction software | woldfw | Tips & Tricks | 1 | 12-15-2005 08:52 AM |
Pitch Correction Software - Opinions | Straatocastoer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 02-22-2004 07:25 AM |
