Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 09-09-2001, 06:26 AM
brett.howard brett.howard is offline
Default fast scsi storage system for way cheap!
Hi All,
Just built a great fast scsi storage system for way cheap. Forget IDE and UDMA this is the way to go. Heres what I did.
Find an old compaq server with onboard UW SCSI (I used a proliant 1500 Pentium 133 that was destined to live in the trash!) and remove the 5 way hot plug drive cradle from it and throw the rest away. Buy a 4u rack panel (£6) cut a large rectangle in it and bolt the compaq drive cradle to it. Bolt on an AT power supply next to it (to power the drives!) stick it in a rack and conect it to an adaptec 2940UW or such like and take advantage of all the compaq 9Gb ultra scsi hot plug drives that are on eaby for like £40-£50 each.
With this system I can have 5 drives in at any one time but the drives are so cheap I can afford loads of them. The drives are real fast, especialy if you use multiple drives at the same time!!!
I have just started building another one for my video edit setup.
A real compaq 19" rack HD system is about £850 + VAT for a 7 way with no drives installed!
Mine cost me about £30 to put together
Hope this inspires somebody!
Cheers
Brett
Storage Q's - Mix - IDE vs SCSI? Magma vs MDD? Table Syrup Records Pro Tools TDM Systems (Mac) 5 11-11-2009 08:44 AM
Could a cheap fw drive used only for storage corrupt PT files? Nash BBQ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-10-2002 03:48 AM
IDE 1394 and SCSI for audio storage of PTLE? t502kg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-03-2002 04:21 PM
Cheap fast storage idea brett.howard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-10-2001 04:04 AM
anyone using the system drive and storage audio drive in the same SCSI chain? riorecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-16-2000 12:09 AM
