Unbalanced TS into TRS jack
Is this a bad idea? I don't have a balanced TRS cable, but I really want to use my TubePre as a DI box. Can I just run a TS cable from the preamp into the TRS input on my Mbox? Is this bad practice, considering I'm running a small scale studio in my dorm?
Jim Carroll |
Re: Unbalanced TS into TRS jack
Using a TS>TS cable to connect a balanced output to a balanced input is not a great idea. You can give it a go if you must, it won't damage anything, but watch out for increased hum and noise.
Obviously, it defeats the purpose of using an external preamp to improve the sound if you use an unsuitable cable that then degrades the sound. |
Running a regular TS-TS cable into a TRS input connects ring and sleeve together, which usually does nothing more but drops it to unbalanced connection. HOWEVER, some equipment make brumming or humming noise by doing this, so if that happens you need to change the cable.
If you make unbalanced connection, you should know that some manufacturers recommend you leave negative/cold unconnected, some recommend you connect negative/cold to ground pin (which is what you're doing if you plug a TS into a TRS). Good luck :)
the seller gave me the wrong cable.transaxle damage to the device?TRS jack unbalanced TS.I will return as soon as possible.What is the damage to the device? thank you
http://www.n2rit.com/audio/audio_connection.jpgIt was mono audio output.
XLR to Unbalanced Phone Jack - Which Pins? | Michael North | Eleven Rack | 17 | 04-16-2014 10:17 PM |
Jack is here !!! | The Lone Roger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 09-17-2013 04:35 AM |
1/4" Balanced Output Jack to 1/4" unbalanced aux input heaphone amp | edgarbc1 | General Discussion | 4 | 12-13-2010 09:00 PM |
Unbalanced Avalon M5? | mantaray | Pro Tools TDM Systems (Mac) | 1 | 09-11-2005 02:33 AM |
Can I go Unbalanced into C24? | Hardnox | ICON & C|24 | 3 | 07-21-2001 12:12 AM |
