Old 07-06-2009, 03:11 AM
nucelar's Avatar
nucelar nucelar is offline
Default reverse effect idea?
Hi, I'm looking for a plug-in that reverses audio in fragments in rtas.
Like:
one, two, three, four, five
eno, owt, eerht, ruof, evif
yes, I could edit and reverse manually, but I'm looking for something automatic and repeatable...
This is for a cartoon, where they travel back in time,
sknahT for any suggestions!
Old 07-06-2009, 03:48 AM
Default Re: reverse effect idea?
Are you talking about the equivalent of playing a tape backwards or the equivalent of editing the parts of the words in different order while the fragments are played forward (something like a granular effect)? If the latter, RiverRun from AudioEase comes to mind or GRMTools´ Shuffle.
Or you could build this in Reaktor if it has to be RTAS. If not Kyma or Max/MSP would also do.
frank.
PTHDn 2019.5 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 07-06-2009, 04:02 AM
mifo mifo is offline
Reversinator does what you are looking for.
But it's VST (Mac PPC or WinXP), so FXpansion is needed.
It's not tweakable, it has just on/off switch...
But it's free.
Best
Michal Fojcik
Old 07-06-2009, 05:39 AM
Carl Kolchak Carl Kolchak is offline
Besides the above suggestions, you might have some luck with Transfuser but I don't know for sure if it will do exactly what you want.
That said, it only takes a few moments to select each word and hit "b" to separate, then select all the words and have the audiosuite "Reverse" plugin render on a region by region basis, rather than the entire selection.
hope that is of some use.
Old 07-06-2009, 05:57 AM
tj_davies tj_davies is offline
Originally Posted by Carl Kolchak View Post
That said, it only takes a few moments to select each word and hit "b" to separate.
Even better: use the silence stripper. And then as Carl suggests - use the reverse audiosuite and set it to "create individual files" / "region by region".
Timothy
G5 10.8.5
PT 10.3.9 HD2
www.pearls-music.com
Old 07-06-2009, 06:15 AM
nucelar's Avatar
thanks for all quick suggestions, i will later play with the GRM tools, they seem to be really cool.. But the client happend to like the sound of the scrubber tool messing around so we just recorded that.
Cheers
Old 07-06-2009, 06:53 AM
... Also Antares Mutator has Alienize option. It does the same, and you can change the grain length.
Michal Fojcik
Old 07-06-2009, 07:39 AM
Man! Even when I'm being a Dumbass I do it in a Halfassed way
Old 07-07-2009, 12:01 AM
lol
Better Halfassed than Doubledumb.
Timothy
G5 10.8.5
PT 10.3.9 HD2
HTML code is On
Can I Add a Reverse Effect on Midi (Drums in Xpand) gavriil1 Pro Tools 10 4 11-28-2012 06:27 PM
reverse reverb effect SublimeAndy Tips & Tricks 4 04-12-2008 01:50 PM
How do you make a reverse reverb effect? deejfro Tips & Tricks 2 02-13-2005 09:24 PM
having trouble doing reverse vocal swell effect Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-06-2003 07:53 AM
onboard sound, good idea/bad idea?! sampb7 Digidesign Hardware & Software 1 02-22-2003 02:44 AM
