Old 01-18-2019, 11:57 PM
Modrob Modrob is offline
Default Newbie: how-to even-out trax timings
Newbie here (my trusty Fostex VF-16 after many solid years gave up) older age, and have ventured into the PT world (dragging my feet for some time) with a version M9. I have to admit that after using it for a few months now I’m becoming more a fan. I’m overwhelmed at all that is possible with this software and several features have already made my recording life much easier.😊
That being said, recently I cut all instruments on an old pop song, without a click, choosing to play along with the original live track. Of course the tempo is moving around some, and I’d like to see if I can somehow go backwards and create a solid click (I usually record a click using an old outboard Alesis unit) but I know that can be generated by PT...
I’ve been looking at the manual, reading and seeing videos about Beat Dectective, Quantizing, etc., but my older brain now just doesn’t grasp things as well as it did years earlier...
This particular track has a lot going on, including three horns. Lastly I’ve spent several hours over days trying play drums to it, but never tight enough. I tapped out a click manually throughout but still...
Is it feasible to straighten out?
Old 01-22-2019, 03:36 AM
Default Re: Newbie: how-to even-out trax timings
Hi, welcome to the community.
It sounds to me you are better off without click... next time record drum kit first
Old 01-22-2019, 12:09 PM
Top Jimmy's Avatar
You need to build a tempo map if you want to be able to quantize your new drums to the original song.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 02-01-2019, 09:08 AM
Maybe I wasn’t clear...
I have cut all the instruments and all have some slight tempo variances due to recording/playing along with an original live track that “moved” in tempo. Is it possible to even out each individual track to a more consistent tempo? THEN I can try adding my drums then...😊
Old 02-10-2019, 10:04 AM
Yes it is possible to create a tempo map that evens out everything, but it isn't a press one button kind of a job. Please download latest protools reference guide and read everything there is about tempo map, then ask more questions
Old 02-10-2019, 10:26 AM
DonaldM's Avatar
DonaldM DonaldM is offline
As Janne and the others have said, you need to create a tempo map off the original track. There's a lot in the manual on how to do this. Also, this video explains the process very clearly. Its not a difficult process, but there's a few steps involved and, depending on how much variance there is, its best to go down the entire track, measure by measure. Good luck!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2018.12
Focusrite Scarlett 8i6
Old 02-11-2019, 07:58 AM
Creating a Tempo Map is probably the best way, but there is another possibility. See if you can find someone with the latest Melodyne Editor(or check Celmony to see if they offer a demo). With Melodyne Editor in stand-alone mode(not as a plugin in PT) its possible to analyze the tempo(revealing any fluctuations) and then you can choose to correct it(even it out). Obviously, you would need to perform this adjustment exactly the same on all your tracks, OR bounce the tracks(without your new drums) to a stereo audio file and use Melodyne to "fix" that. Then import that into a new session so you can add your drums(with a click at the corrected tempo)
HP z820 12 core, 64GB RAM, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs, Warm Audio and Midas..............................
help setting up ram timings please Raoul23 Pro Tools 10 7 05-31-2012 07:36 AM
Exporting timings from track ysiddiqui Pro Tools 10 0 04-02-2012 05:29 PM
RAM Timings Zenman Pro Tools Software (Win) 6 07-07-2011 07:50 AM
RAM timings sw rec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 12-31-2009 02:57 PM
Visual Countown for ADR/VO timings for talent? masterboyle Post - Surround - Video 4 08-03-2009 03:39 PM
