Old 01-08-2004, 02:07 PM
poppy poppy is offline
Default Transferring Hard drive between Macs
Sorry if this is a bit of an off-topic and maybe a silly question.
Let's say I want to change Macs can I simply switch the internal system drive from one to the other
in order to avoid having to reinstall all my software.
I want to switch from a G4 400 to a G4 733
Thanks
Old 01-08-2004, 03:44 PM
MoreMeintheMonitors MoreMeintheMonitors is offline
Default Re: Transferring Hard drive between Macs
Usually this is not a problem.
Old 01-08-2004, 03:58 PM
TiPo TiPo is offline
You can also connect the new machine to the older one through a FireWire cable and startup the new machine while holding down the "T" key. After this you can see a firewire HD icon mounted on the older machine desktop. After this you use Carbon Copy Cloner to Clone your old machine HD to the New Machin HD so you can use the newer HD.
You need OS 10.x.x for this!
TiPo
Pro-Tools 10.3.10 HD 2 Accel PCIe
OSX 10.10.3
Old 01-08-2004, 11:38 PM
Monte McGuire Monte McGuire is offline
One thing to keep in mind is that some forms of copy protection are keyed to the CPU as well as the hard drive, so these won't travel when you switch drives. At least this was the situation with ProTools under 9.x and below - you didn't mention what OS you were using.
A friend recently tried this when switching from a 9600 to a G4, both under 9.x, and it didn't work out so well.
-monte-
Old 01-09-2004, 09:19 AM
trakbytes trakbytes is offline
Since you're switchng between two G-4's of similiar architecture, it will probably work. I would recommend zapping the PRAM upon startup (hold down command-option-"P" and "R" for three startups after you swap. This will re-set the parameters for the new hardware.
You definitely can't switch between a 9600 vintage and a G-(anything) since the system disks are different-9600's and earlier use SCSI, and everything later is IDE.
rcm
Save early and often! (or once a day whether you need to or not...)
Old 01-09-2004, 09:46 AM
As I've stated it in the last line of my first reply it works properly under OS 10.x.x.
It worked for me perfectly.
There is no CC Cloner below OS 10!
TiPo
OSX 10.10.3
Transferring sessions to a new drive DonaldM Tips & Tricks 3 11-19-2010 09:46 AM
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
Disc Allocation when transferring session from drive to drive... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-17-2003 03:37 PM
Finding audio files after transferring all floders to another hard drive Somebody Pro Tools TDM Systems (Mac) 6 11-28-2002 02:21 AM
transferring hard drives... metaltim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-19-2002 11:24 AM
