Eleven MK II in Pro Tools 10?
Hi..
I'm running pro tools 10, and I've just upgraded eleven to eleven mk2, but can't seem to get it to work..The 10.3.3 installer just installs version 1.. Has anyone got the proper installer, or what one should I use? Thanks.. |
Re: Eleven mk2
Did you try the v12 installer?
For PT10 you would want the RTAS or AAX32 bit version, but I can see that going through the install doesn't give you any format choices and the 10.3.3 version just installs the LE version and TDM version which is indeed v1. I'd try the v12 installer.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Re: Eleven mk2
Did you try 10.3.7 or 10.3.9 updated that might help u. But don't quote me on this tho: :)
Sent from my iPhone using Tapatalk |
Re: Eleven mk2
Hi..Yeah, I tried the 12 installer..no joy, although I might have had v1 installed at the time, so I'll try it again..was hoping someone might have gotten it working..avid said to use the 10.3.3,..there's surely one that works somewhere..
Re: Eleven mk2
Tried the 12 installer there again with no previous version installed..it seems to have installed on the x64 side of Windows(7)..even when I moved it to the x86 program files folder it doesn't work..
Re: Eleven mk2
Anybody?..Has anyone got eleven mk2 working with pt10?
Re: Eleven mk2
Do avid tech support not answer questions here no?
Re: Eleven mk2
Not really. If you want support from Avid you get to pay for it, or at least burn a complimentary ASC. The Avid web site has all the info you need to contact support.
Re: Eleven mk2
Thanks for your reply..
But they are on the forum aren't they?..I've already spent e105 on the plugin..instead of the $99 that was advertised to get me there..I emailed them and after 3 emails she just stopped replying..It's advertised as working on pt10..I've wasted e25 to ask them a question before..this is a joke.. |
Re: Eleven mk2
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! | Justin1524 | Eleven Rack | 0 | 11-27-2015 02:53 PM |
Eleven LE, Eleven Full, Eleven MK II Compared | Justin1524 | AAX Plug-ins | 5 | 11-19-2015 02:47 PM |
Eleven Rack and Pro Tools Eleven | chrisdesherlia | Eleven Rack | 10 | 06-13-2014 07:17 PM |
Eleven in pro tools 8 | landros | Pro Tools TDM Systems (Mac) | 4 | 05-05-2010 11:04 AM |
Eleven LE/Pro Tools help | JmanPugs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-12-2009 06:53 PM |
