Modern motherboard for original PCI HD Core and Process cards
Hi Everyone,
About 9 months ago I posted looking for help building a modern computer with all the latest and greatest but still able to support my original PCI HD Core and Process cards built in 2002. Now it looks like I will be able to do this in the next 3 to 4 months so I wanted to get some current ideas and feedback. I talked to AVID at NAB and they said it should work fine with PT 9 and Windows 7 once I can find a motherboard with two legacy PCI slots next to each other that can accept two full length cards. If I can find a motherboard that supports the cards and has all the modern stuff like PCIe, current ram / cpu technology, SATA II etc... I can build the computer around that. Any suggestions on motherboards to look at? Thanks, David |
Re: Modern motherboard for original PCI HD Core and Process cards
Adjacent PCI slots are no longer necessary. I have a solution. Contact me directly if interested. My contact info is in my public profile here.
Hey David,
I'm using this one : GIGABYTE GA-P55-UD3L Not easily available, found mine on ebay, have seen a few others. On the plus side, it has 4 PCI slots and 3 PCIe, Sata and supports an Intel I7. On the minus side, the MB requires a bit of modification to get the PCI cards to fit. (Dremel tool to the rescue) Also, no USB3 and no on-board Firewire. I've added a FW card to the system, only good for transferring files, can't run a session off it yet. I'll continue to trouble shoot that. For now, my HD3 Accel lives on, running great PT9 HD on Win 7. I'll likely add a fourth Accel card. I do miss my Mac but getting this rig operational has been worthwhile. good luck |
Thanks for the MB suggestion. Using the Dremel sounds risky and ideally I would like to avoid that.
Aren't there any brand new boards I can buy that will do this? |
Supermicro X8SAX, our HD3 PCI system runs great with this motherboard.
https://www.thirdeyerecording.com/ |
Thanks Third Eye, that looks promising. I'm not quite sure how you got 3 PCI cards in there because at least the picture on the manufacturer's website:
http://www.supermicro.com/products/m.../X58/X8SAX.cfm only shows 2 slots that I believe the cards would fit in. Listed in the specs are 1 32bit PCI slot and 2 64 bit PCI-X slots. I have 2 PCI cards that are not PCI-X although I am hearing from multiple people that my cards will work in a PCI-X slot. I will do more research to understand the differences between PCI and PCI-X. Thank you everyone for your thoughts! |
Thanks for the info! Did you have any tips for building a computer with this MB? Things you ran into that you had to solve? Was it fairly straight forward?
Thanks, David |
Hi David, The build was very easy. I put it all in a huge case, and it was really a piece of cake. It's been a great, powerful system.
Which CPU did you decide to go with?
What is the thermal output/heat load of HD core cards and process cards? | yosemitesam | Pro Tools TDM Systems (Mac) | 0 | 10-24-2011 02:39 PM |
Remote access to HD Core & Process Cards though the LAN???? | pmcmurt | Pro Tools TDM Systems (Mac) | 3 | 06-06-2011 11:15 AM |
Motherboards and systems for use with original HD core and process cards? | David Sandwisch | Pro Tools TDM Systems (Win) | 16 | 04-20-2010 06:42 PM |
PCI-X G5 and HD core and process cards | Charles Schaefer | Pro Tools TDM Systems (Mac) | 5 | 12-26-2005 02:23 PM |
HD Core and process cards faulty??? | Michel | Pro Tools TDM Systems (Mac) | 7 | 03-09-2002 04:59 AM |
