  #21
Old 11-19-2019, 03:48 PM
paulo m's Avatar
paulo m paulo m is offline
Default Re: Dolby Atmos hardware requirement for Production/Mastering suite
Originally Posted by JanuS View Post
Well, in PT 2019.10 and with the new Dolby Audio Bridge in v3.3 you can now!
In my understanding, the DAB is only for the Production Suite, running on the same machine as PT. It´s a computer internal bussing.
For an external RMU you will need physical interface connections, either MADI or Dante, the ethernet connection for metadata and the LTC source from PT.
Regards,
Paulo M
  #22
Old 11-19-2019, 03:51 PM
paulo m's Avatar
Originally Posted by Mishabou View Post
I'm using PT Ultimate with Thunderbolt Native and DAD AX32. I thought one needs 2 x HDX card to get more than 64 I/O.
Which by the way, DAD does not sell anymore (digilink expansion card) as part of the agreement on manufacturing the MTRX for AVID.
Regards,
Paulo M
  #23
Old 11-19-2019, 09:00 PM
lucienpalmer lucienpalmer is online now
I think he might just referring to needing two HDX cards for Pro Tools. Not two digilink expansion ports on the MTRX. I could be wrong.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
MacPro 3.45 12-core, OSX 10.12.6
S6 M10 16-5, Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
Certified for Dolby Atmos Home Entertainment
  #24
Old 11-20-2019, 12:11 AM
JanuS JanuS is offline
Indeed, it's an internal bussing audio engine for the Production Suite. So no send/return structure anymore (although you can still use that setup).
This makes the step of premixing Atmos in a small room, going to a RMU equipped stage a lot faster / easier!
  #25
Old 11-20-2019, 02:05 AM
nedd nedd is offline
Can someone elaborate what are the steps that needs to be done when going from HDX (send/return) set up to the RMU equipped Atmos stage? Can that be prepared before sending session over? How much time approximately is needed?
  #26
Old 11-20-2019, 07:55 AM
quadraphonics quadraphonics is offline
When using the DAB, the first step is to set the playback engine in Pro Tools to Dolby Audio Bridge. That gives you 130 output channels (in PT 2019.10+ only). The 128 are what feed the Local Renderer software(on the same computer) In the Audio setup part of the Local Renderer, you would set the Input to Dolby Audio Bridge and the Output to HDX.
You will not be able to use the send/return plug ins in this setup. You will set the output routing in the I/O page of the pro tools session to match the inputs (Beds/Objects) for the Local Renderer.
This setup is really meant for things like pre-mixes and the like. Dolby will tell you that this is not a great way to create masters.
For some of the other questions, Pro Tools can only output 32 channels of audio per Digilink port - so 64 channels per card.
The MTRX can output a ton of audio, but only functions out of the box as a 64 channel PT interface. This can be augmented with additional Digilink ports.
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
  #27
Old 11-20-2019, 07:43 PM
Mishabou Mishabou is offline
So bottom line, if one uses a dedicated HT RMU, the PT Ultimate rig must use 2 x HDX cards because this is the only way to have 128 outputs, correct ?
I have a nMP with PT Ultimate (thunderbolt Native), AX32 with Digilink (same interface as MTRX, i bought it before Avid team up with DAD). I also have a spare nMP with Rednet PCIe Dante that i was thinking of using as a dedicated HT RMU. If i understand correctly, i will need 2 x HDX card and an additional Digilink card for my AX32 for it to work, correct ?
  #28
Old 11-20-2019, 08:13 PM
LDS LDS is offline
You require HDX2 for 128 channels of outputs from Pro Tools... but unless you are reaching for Dolby Atmos certification, I don't think you need to actually use 128 channels. 64 channels would still give you a bunch of beds and a lot of objects to mess around with!
littledevilstudios.com.au
Pro Tools Ultimate 2019.6. OSX 10.14.6. HDX. Avid Omni. MacBook Pro 2018. 6 Core i7. 32Gb. 4x mSata SSD Drives + 4x HDD. Blackmagic Intensity PCIe. ATI RX580. Sync HD
  #29
Old 11-20-2019, 09:41 PM
pablovius pablovius is offline
I tend to agree with LDS. For those of us HD Native users mixing docs, dramas, un-scirpted, etc.-- 36 bed channels (3x 7.1.4) and 16 object channels and 12 for monitoring seems more than adequate... am I missing something? Otherwise we're talking HDX2, additional dig-link, et. al.--a much larger barrier to entry.
  #30
Old 11-21-2019, 04:46 AM
BScout BScout is offline
Can't get that for the AX32. Only the MTRX supports the new digilink cards.
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
HTML code is On
Dolby Atmos Production Suite 3.02 download LDS Post - Surround - Video 3 08-20-2019 08:03 AM
Dolby Atmos Production Suite renderer on another computer nedd Post - Surround - Video 7 04-24-2019 09:11 AM
Dolby Atmos Production Suite Installer V 2.5 tatoflores Post - Surround - Video 1 04-21-2019 10:46 AM
Dolby Atmos Production Suite garnoil Post - Surround - Video 2 03-13-2019 09:34 AM
Dolby Atmos Production Suite subhuffer Post - Surround - Video 20 03-10-2019 07:40 AM
