Old 06-02-2010, 11:09 PM
Boogie457 Boogie457 is offline
Default Unknown MIDI note appear after recording HELP!
When I record midi, pro tools will create a tiny midi note before the regular one and when i does this, certain instruments like acoustik piano notes will get cut off. So then I'll have to go into the whole piano performance and delete all of these annoying midi notes. I've already tried deleting all prefs and don't know what else to do besides wiping it and reinstalling! HELP! thanks in advance
Old 06-03-2010, 01:35 AM
440Hz's Avatar
440Hz 440Hz is offline
Default Re: Unknown MIDI note appear after recording HELP!
I am having EXACTLY the same problem.
This has lead to a complete system overhaul. Loss of plugs and no end of hair removing hassle.
After doing all recommended Plug updates, Trash prefs etc etc I recorded another session and found the EXACT same issue.
May I suggest you post your system spec, plugs version list etc and hopefully DIGI will chime in and rescue us both.....
Old 06-03-2010, 03:00 AM
tamasdragon tamasdragon is offline
My first bet would be some plugin incompatibility, but without further info, it would be hard to help.
Have you both checked plug compatibility at least twice?
my blog:Tamas Dragon
Old 06-03-2010, 03:52 AM
Husmas Husmas is offline
I had the exact same problem. I use an mbox2 and a macbook pro and the solution was to connect my midi keyboard directly to the macbook with usb.
No midi cables, what so ever.
Did the trick for me.
Hope this helps
Old 06-03-2010, 04:59 AM
Hope this helps
Good idea. It can be even the keyboard they're using.
Old 06-03-2010, 07:09 AM
440Hz's Avatar
I just sorted out my same issue.
It was a setting within the midi controller (Axiom 61).
Did a reset on the Axiom and all is well in MIDI Instrument land.
I think you need to set it to Local Off.
Old 06-03-2010, 11:43 AM
DigiTechSupt's Avatar
It's not local-off that's the problem (and it's not an option on the Axiom), it's most likely that you have multiple zones overlapping on the keyboard. A zone defines which MIDI channel a certain number of keys will transmit on. You could have, for instance, 2 different zones - one for keys higher than middle C, one for ones lower than middle C - and have them transmit on different channels and trigger different VI's in Pro Tools.
You could also have those zones overlap, so pressing 1 key would send out on 2 MIDI channels. This is one scenario that can cause this problem unless you're channelizing incoming MIDI data - meaning selecting a single MIDI channel on the MIDI input of a track. If you don't do that, the track MIDI input merges the data and can mix up the note on/off messages for each note.
Another cause could be MIDI echo, where a track output is routed to the same keyboard that transmitted it and that keyboard is set to echo it's MIDI input to it's MIDI output.
Local 'Off' or 'On' would only apply to keyboards that have built in synths - Local control is the internal MIDI data bus between the keyboard and the synth engine. Having this on wouldn't usually cause the symptoms in this thread, but it can be the cause for double-triggering, but only while playing. What happens is the keyboard internally sends MIDI data to the synth and you have the actual MIDI output that goes to your DAW being routed back from the DAW to the MIDI input, creating another note trigger.
Lastly, sometimes the 'Default MIDI Thru' instrument can cause the symptoms described in this thread. Changing it may fix the problem. Which setting is best depends on your particular configuration - the Pro Tools Reference Guide has more info about how each setting works.
Avid Audio Tech Support
Support FAQ
Old 02-10-2015, 09:01 PM
sonicpalace sonicpalace is offline
Thanks, I just spent 2 hours trying to figure this out with my Oxygen 8 (old) and Pro Tools 11. I'm using a midi man 2x2 as the midi interface.
When I select the midi man 2x2 port "A" the mysterious clips are gone thank God, u were not invited to the party! It was a real drag with mono sounds because when I quantized them the whole track pretty much stopped playing, thanks!
Old 03-23-2015, 04:43 AM
cherryred335 cherryred335 is offline
I too am getting this unwanted occurrence with my new Axiom 49.Any help on what I should try first to eliminate this would be extremely helpful.
Thank you.
Al
midi recording - note durations busk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2011 09:51 AM
Pro Tools sends MIDI C note while recording I/O_Madness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-14-2010 09:23 AM
1/64 note latency when recording MIDI to Audio Jean-Michel MIDI 1 05-21-2009 12:28 PM
When recording throough USB MIDI, first note is cut.... Justbleazy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-01-2009 11:02 AM
MIDI recording - lost first note tribase Tips & Tricks 0 03-10-2006 10:49 PM
