input assignments reverting
how come when i assign "no input" to a track with a no longer valid input path, it always reverts back to the invalid path when i close and re-open it?
Re: input assignments reverting
Yeah. Same problem... driving me crazy. I'll open a session from somewhere else, change it all over to my i/o settings (even that is buggy - have to import it multiple times to make it all work), deleting the unused old i/o settings as I go through the import settings process (multiple times)... but even after saving, whenever I re-open the session a few of the old inputs show up grayed out... It's never all of them....
I do not have "sessions overwrite current I/O Setup when opened" selected in the I/O setup window. What else could it be? This seems like a very simple issue... maybe I'm missing something? Just glad it's not the outputs!! PT HD 9.0.1, Mac 10.6.6 |
It's also partly the outputs as the darn IO setup does not remember your default output setting if you change it to your own preference. That is extremely maddening and can cause havoc at times.
Hope they fix it soon! best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
I hope they fix ALOT of things soon!
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
I can see the beauty in the new I/O bussing-to-actual-outputs scheme. I probably shouldn't be surprised that it's a little buggy considering the complexity of it all. But it is surprising that I have to load my I/O setup multiple times to get the labels to be correct... (and then change the default outputs manually). It's like PT doesn't believe me until I tell it to do it three times. :) Just like my toddler except not as lovable. Anyway - if anyone has had luck in making a new I/O setup I'd love to know. I'm not getting my hopes up. |
Update: within a minute, I realized that PT had not simply renamed those busses, it actually re-assigned those busses to new paths. i.e. "MixBuss" was now had nothing going to it, but "bus 35-36" has everything that was previously aimed to MixBuss. . . . Even more disturbing. . . .
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
I assume Avid is aware of the issue - I did a few searches but haven't seen many other users complaining. (maybe I didn't enter the right search terms)
Has anyone heard from Avid on this? |
Tech Support have logged the "default output setting" issue for a fix. No timeframe was mentioned. As for the rest of this, I don't know.
That seemed to be working pretty well until recently. Quite honestly, I'm not even sure if we're dealing with bugs or just nobody really understanding all the ins and outs of this new I/O window and how it's going to behave "intelligently."
how to find non-existant input path/buss assignments? | wildhair | Pro Tools 10 | 4 | 07-28-2012 03:33 PM |
Changing track input/output assignments corrupts session files, causing PT to crash. | horribleheaven | Pro Tools M-Powered (Win) | 1 | 07-08-2010 11:47 AM |
Reverting back to 7.0? | AfterimageMetal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-23-2007 01:25 PM |
Bought 7.3, Reverting to 7.1.... | sean shannon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-13-2007 01:36 PM |
Reverting to 5.3.2 | Zoduati | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-18-2004 06:13 AM |
