VEPro on Slave Mac
I'm running PT on a Mac Pro 2.26 (Nehalem) and I want to use VEPro on a iMac 3.06 as a slave by way of LAN.
Anyone here successful in doing so? Thanks!
Dean |
Re: VEPro on Slave Mac
Yes, works quite good here... Best Chris |
I LOVE this setup. And I absolutely adore VE Pro....
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
We have a couple of very comprehensive VE Pro threads here. You might want to read these... J
--Jeremy |
Like Chris said, it runs just fine residing on the same computer as P Tools.
I run VEPro 64 bit on a Windows 7 Pro PC (8GB RAM) on a LAN with my Pro MAC and Pro Tools HD 4. I use MIDI Over LAN v3 and Windows Remote Desktop for Windows. So far this setup has been great! I can run over 8 instances of Omnisphere at the same time in VEPro 64 bit. Although I typically will run East West Symphonic Play, Omnisphere, and Kontakt 3 in VEPro 64 bit.
-Mark |
Thanks for the info folks.
I am presently using VEPro on the same computer as PT's, but I have quite a large Orchestral and Drum library and need the second computer for the power. If I try loading everything onto the main computer, PT's CPU gauge surpasses 100% and completely stops working. So yesterday I hooked up my MacBook Pro to the Mac Pro by way of LAN. I inserted the eLicenser key in the MBP and installed VEPro and Kontakt 4.1. I connected the MIXOSAURUS drive to it. I used Remote Desktop for viewing purposes on my MP. I launched Directory Manager on the MBP and added the MIXO folder. I launched PT's on the MP and instantiated VEPro on a stereo Instrument track. I could play and hear MIXO without any issue's. The problem occurs when I add an AUX track in PT.s PT's freeze's and crashes. This occur's every time I try to add an AUX track. Is anyone else having this problem? Maybe something is not correctly checked? What I'm trying to do is create 8 AUX tracks in PT's so I can have multiple drums outputs. Is this even possible or do I have to use another DAW on the MBP? I really don't want to use another DAW. All I'm interested in using is VEPro. Also if this does work, I plan on getting the iMac 3.06. I think that should work much better than my MBP. Any help would be appreciate. Again, thx.
Dean |
Im using PT8.1.cs1 on a macpro 2.66GHz quad core intel xeon,and running VEPro on an Imac 2.66GHz intel core I5 with no problems at all.I love it.Only thing i had to get was an ethernet switch.i'm using a Dlink DGS 1005D.All works a treat,i recommend it,i have both servers going 32bit and 64bit.I have my outputs all coming up on audio channels set to input monitor.ready to record if and when i want to.
Hey guys- is the Mac Mini 2.4 strong enough as a slave for large orchestral type samples?
Thanks!
Dean |
bump
Dean |
VEPro & PT & ADC | musicman691 | General Discussion | 0 | 03-06-2012 04:58 PM |
VEPro 5 on a slave Mac Pro - Dropouts | Imagine | Pro Tools TDM Systems (Mac) | 0 | 12-06-2011 12:24 AM |
VEPro and Stylus RMX | Ray Lyon | Virtual Instruments | 2 | 05-25-2011 06:29 AM |
Good computer for VEPro as slave? | Ray Lyon | Virtual Instruments | 3 | 03-14-2011 06:39 AM |
korg d1600 being slave a slave to pro tools | sbag | MIDI | 0 | 04-12-2007 06:50 AM |
